![]() | Home > In Car Electronics > 2004 Defender Td5 Towbar connections |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2291 ![]() ![]() ![]() |
Sorry this probably isn’t much help…
The plug/socket is behind the OSR light panel (behind the plastic cover). I don’t recall seeing any other ‘spare’ plugs or sockets when I changed mine a few years ago. Here’s the wiring diagram below: ![]() Click image to enlarge I tried to take a photo of the cable/plug but it didn’t work on the dark ![]() I suspect you’ll need to provide a fused unswitched positive to achieve your desired outcome ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17947 ![]() ![]() ![]() |
No, since the 13-pin socket is an amalgamation of the 7N and 7S sockets, it involves about the same amount of installation effort as a 7S if you want it to be fully functional. It isn't plug and play.
The 13-pin socket is also an MOT testable item, the 7-pin sockets are not. |
deejayen Member Since: 18 Sep 2017 Location: Inverness Posts: 56 ![]() ![]() |
Thanks very much!
It sounds like the sort of job for which I'll have to enlist some help! |
