Home > Maintenance & Modifications > Hinge Fitting Advice
The Fox
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Got myself some shiny new Optimill rear door hinges to replace a set which were shot.
The bottom hinge (the awkward one, naturally) just doesn't want to line up. I can get one bolt through, but the holes in the body just don't line up with the holes on the hinge. The holes on the Optimill's line up perfectly with those on the old steel hinges.
I've tried loosening all the others and lifting/adjusting the door fit - but the holes just fundamentally don't line up. One of the holes is an oval from the factory - so I'm guessing they were just done poorly from day one.
Do I:
1. Make the other hole an oval and get the bolt through - drilling the body fills me with dread
2. Undo the lot and refit again - it's probably my bad alignment (how, if the holds just don't align...)
3. Just leave the bottom hinge with one bolt through the body - feels like the wrong idea
3. Other - answers on a postcard
Your sage advice gratefully recieved
Post #946617 22nd Mar 2022 4:49pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Option 2, if the new hinges have the same bolt spacing as the originals then they will fit. They can however be quite tricky, especially if you're fitting them on your own.
I'm isolating at the moment but am not far from you so would be happy to give you a hand if needed? In the meantime, it may sound obvious but have you tried slackening off the the top hinge bolts? You may find the door is being pinched, preventing the second bottom hinge bolt from lining up.
EDIT
Something else to consider, are the threads ok? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #946624 22nd Mar 2022 5:44pm
BrickBox
Option 2. 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #946626 22nd Mar 2022 5:45pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Option 2 - loosen (don't remove) the bolts in all 3 hinges and you should be able to line up the bottom hinge. Worked for me! Just because you're offended doesn't mean you're right.
Post #946665 22nd Mar 2022 9:31pm
MikeSel
There’s a video on YouTube by The Doctors Garage of him fitting them. He has some tips in there, maybe worth a watch. Smile
Mine should arrive today, so interested to hear how you get on. Good luck.
Post #946709 23rd Mar 2022 9:10am
The Fox
EDIT
This was my conclusion too - if the originals fit, why not these.
I'll have a go at Option 2 later today (at least we've got some nice weather for it) and report back.
Many thanks for the offer of help - I may well take you up on that!
Post #946714 23rd Mar 2022 9:51am
DSC-off
I had the same problem with the holes not lining up.
Something was clearly wrong, possibly why original top hinge broke
In the end I fitted the door on the top and bottom hinges, so it fitted the aperture and swung freely.
Then fitted the middle hinge, slotting the holes in the body to get the screws in.
Post #946722 23rd Mar 2022 11:24am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Remember Defender were hand built, tolerances are a bit vague.
When I did the same on mine, I had to open out a couple of the holes in the body by 1 - 2 mm. Then a dash of Duralac when you fit.
Post #946740 23rd Mar 2022 3:31pm
