Home > Td5 > Handbrake adjustment TD5
alexatnd
Probably simple question,
Handbrake really needs adjusting up, which end do you do it at ? Handbrake linkage in cab or down by the transfer box ? Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #946262 19th Mar 2022 1:01pm
geobloke
On a TD5 it is the square adjuster on the back of the backing plate.
Rear wheel up
Hand brake off
tighten adjuster until it bites then back it off until the rear wheel spins with minimal brake drag.
Test hand brake lever position.
If happy test the hand brake on a slope to test it holds.
Thumbs Up
Link to youtube https://youtu.be/TwPAmQtWaH4
Post #946263 19th Mar 2022 1:23pm
alexatnd
And it works, simples!
many thanks for this
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #946401 20th Mar 2022 8:48pm
Screbble
Rear wheel up
Hand brake off
Thumbs Up
That’s really useful - thanks for the info and link Thumbs Up
Post #946403 20th Mar 2022 8:57pm
geobloke
Thumbs Up
You're both welcome.
Post #946406 20th Mar 2022 9:18pm
alexatnd
Minor thing,
its a 17mm socket you use to adjust it
Post #946455 21st Mar 2022 12:13pm
Screbble
Thumbs Up
Post #946822 23rd Mar 2022 11:00pm
