![]() | Home > Off Topic > Chopping hole in log cabin |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 204 ![]() ![]() |
Hi,
I’m about to ‘knock through’ from one room to another, ie cut through the 44mm thick timber and want it to be straight and square ready to fit a doorway and door, with as little mess as poss. What would you use and how would you go about it? I have a choice of chainsaw, circular saw, carpentry-type handsaw. I think it’s too thick for my jigsaw and that’d probably be a bit wobbly anyway. Cheers, Matt |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Circular saw with a guide plank or track saw finish with handsaw then line it out
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
Just eyeball it with a recip saw
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3770 ![]() ![]() ![]() |
Tracksaw. I’ve got a Festool TS55 that would do it if you want to borrow it. I’m in easingwold. I imagine you would use a blade doing a door way but it will be straight as a die. I’m away for the next week though so no good if your in a rush.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
Lovely bit of kit Co1. And just love how this forums members are happy to help each other out even with non defender related issues. Guess it’s in our collective nature, and long may it last.
Thanks a lot all.
Co1 that’s very kind of you. I’ve not used one before and wouldn’t want to do my test run using your kit. If you’re likely to be heading Dunnington way I’d happily sort you some beer tokens if you have the time for a bit of supervision / assistance, understand if you’re flat out though. Not in a desperate rush, feel free to drop me a PM otherwise I’ll crack on with the guide plank, circ saw and hand saw. Cheers, Matt |
No worries Matt, but I’m tied up for the next few weekends with no plans to be over your way. Have a look on line, it’s not hard to use and there isn’t much you could do to damage it!! Failing that, the circular saw against a straight edge is a reasonable second choice and will do a decent enough job.
Oh, and by the way - we need before and after pics!!
Well if you'd asked my stepfather how to insert a doorway in to a log cabin he'd have reached for his chainsaw. He was a Canadian lumberjack for way too many years. It is incredible what he can do with a chainsaw.
Love a log cabin. Built a small one room Air BnB one a few years ago. Super cosy. ![]() Pictures when you're done |
