Home > Td5 > Belt Tensioner broken tab in holding bracket
andylee
I was changing the belt tensioner today and the positioning tab on the old tensioner has broken off in its mounting plate. Is it possible to remove this plate to drill it out or is it a case of removing the radiator and drilling it out in situe ?? Any advice here is appreciated as I cant seem to find a part number for the plate or a diagram that shows if it is removable. I notice it has a torque bit so hoping I can just remove it and drill but just wanted some advice from the more experienced,
thanks in advance.
Post #946264 19th Mar 2022 2:01pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
That bracket will come away from the block. You’ll need to undo the Torx headed bolt that supports the alternator (there is a captive nut on the other end) then undo the three bolts that secure the bracket to the engine block. See pic below.
Post #946265 19th Mar 2022 2:53pm
andylee
Thank you for you response, thats really helpful.
Do you know if it's possible to remove this mount without having to remove the alternator with it ?
Im thinking I might be able to support it in place whilst I attend to the bracket!!
thanks again
Post #946266 19th Mar 2022 3:15pm
Penfold_6290
The alternator is supported at the top as well, so without the belt tension to worry about you should be able to leave it in situ. Just make sure you’ve disconnected the battery as you don’t want any metal contact with the live terminal on the top while you’re messing about down there.
Post #946268 19th Mar 2022 3:21pm
andylee
Thanks a million, got a bracket from the scrap yard on the way.
Post #946271 19th Mar 2022 4:12pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
This happened to me as well.
I carefully cut the middle of the broken pin out with a pointed carbide burr in a Dremel.
Pulled the remnants out with a pick.
Took only a few minutes.
Be super careful to control the cutter…..but I was able to do it easily without removing the bracket and leaving everything in the vehicle . The pin is not very deep as you can tell from your new one.
Patrick
Post #946312 20th Mar 2022 2:14am
geobloke
Not seen that before, definitely worth dabbing a bit of anti-seize on that peg before fitting the tensioner.
Good luck sorting it out. Thumbs Up
Post #946322 20th Mar 2022 10:06am
andylee
Thank you to everyone who responded with helpful advice I can now close this thread and just add my thoughts in case this happens to anyone else and they find this thread useful.
I bought a replacement part from a breakers yard but didn't need it as once I had removed the bracket, which was a bit of a fiddle but totally doable without having to remove the alternator, I could drill out the broken tab using a small bit then getting bigger. It then just popped out as the last bit shredded.
Refitting was a bit easier as I cleaned and sanded all the joining surfaces adding some copper slip, as suggested also to the new tab and mounting surface of the tensioner in case this has to come of at a later date. Belt and fan back on and hey presto back in the game, ready for the next bolt to break!
The only special tools required where a thin walled 14mm 12point spark plug socket for the bolt that holds the tensioner on, a Torxbit not sure what size it was and a spanner set for removing viscous fan otherwise all standard stuff.
Thanks again and have a nice weekend.
Post #947097 26th Mar 2022 1:09pm
geobloke
Excellent. Glad you are up and running again Thumbs Up Thumbs Up
Post #947113 26th Mar 2022 5:05pm
