![]() | Home > Maintenance & Modifications > which wheels need to decide by tonight ??? |
You should not put 285's on wheels less than 7.5 inch however there are plenty here that do and do not suffer problems but it is a safety issue.
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
yep already know that he was going to put the disco zu rims on as they are 8 inch and have wheel hub adaptors but due to alot of people with 7inch wheels putting 285 he thinks sod it so what you recon then which ones ???
As ZUs are Mach 5 'wannabees' and I have Mach 5s out of the two I would naturally go for the look of the ZUs.
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Out of those two I'd go for the xtech
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
Xtech
![]() Andy |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
I'd go for the Zu ........................ IN SILVER
predicted you would say silver dave
Looks like i said it twice ![]() |
Predict this too.....
Black! ![]() Same as my suggestion for the grille on your other thread! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
