![]() | Home > Technical > Optimill reversing camera/number plate installation issues. |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 845 ![]() ![]() ![]() |
Sounds like a crossed wire. The number plate connector is totally seperate from the camera unit.
Will the led light on the number plate work if that’s the only thing plugged in. Then try disconnecting the feed at head unit and plug in the piggy back loom to the camera. On the head unit you should be able now to select the camera and if you put it in gear it should work (won’t work out of gear as no power to it without reverse light) If that’s all ok then you plug the red wire into the reverse connector on head unit it’s the head unit causing the circuit to blow. What head unit is it? I did mine a few weekends ago. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
