Home > Puma (Tdci) > Red DPF Lamp..what are my options?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
I’ve only got
Limp mode now due to red DPF light. Unfortunately as it’s a second vehicle
It does sit for times and it’s only have 32,000 miles on her (2014 2.2)
I’m on holiday so needing some
Guidance on what to do. And also seems like no good scanner for the 2.2 that does force DPF things?
Help!
Post #945766 14th Mar 2022 5:28pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
you've had the red dpf light on for a few weeks now, no?
At this point you're probably going to need someone with dealer level tools to force a regen. Roaming around 🇳🇴🇨🇭
Post #945769 14th Mar 2022 6:08pm
big110
Yes about a week but today was the first day we tried to drive faster than moving from parking spots so didn’t know limp mode was on.
I’d purchase a scanner to have handy to do this but can’t figure out which is reliable and reputable scanner tool to always have with us.
Post #945774 14th Mar 2022 7:13pm
big110
If I find a used Hawkeye from a discovery can I possibly add puma 2.2 on it?
Post #945776 14th Mar 2022 7:26pm
big110
Well, finally the Autel MS906 arrived. Found one cost me my left teste but I don’t need more kids so it’s ok Rolling with laughter
Was able to get her out of limp mode, did a DPF spray and then ran at high RPMs after 20 min. Great amount of white smoke and junk. Then took it for an hour ride with the scan tool hooked up and watched the live data feed. All looked very good and I was able to do a regen on the filter via scan tool and got the soot level down to 2% if I remember correct.
Just learning the capabilities of the scan tool but already proved its value. Quite a bit different process compared to my first 19j!
Cheers!
Post #946837 24th Mar 2022 2:59am
