Home > Maintenance & Modifications > Pet Hate - Grease Guns
discomog
Pet hate - grease guns, in particular always getting air locked. I now use an air operated one in the garage which doesn’t seem to suffer from air locks. However I have a number of agricultural machines which are too far away from my garage and therefore have to use a lever type with the above mentioned problematic air locks.
Does anyone have experience of the suction type lever grease guns such as Speedy Grease which according to their marketing bumf does not suffer from air locking? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #945616 13th Mar 2022 12:17pm
markb110
Doesn’t it have an small bolt (screw) that you can remove to purge the air.
I can’t even remember the name of the hand operating grease gun I have, I had it for years but now and again I take out the screw, pump it so grease comes out then replace.
Might be worth another look as it may not be obvious.
Thumbs Up
Post #945620 13th Mar 2022 1:01pm
Quite often this is a symptom of the grease drying out in the gun.
Post #945621 13th Mar 2022 1:23pm
Grouse
Buy a Fuch Reiner Grease Gun, seriously these are the best - see hyper link below.
We have tractors, 360 diggers and quite a bit of other plant and equipment and use a fair bit of grease - theses are seriously the best grease gun, never block and more importantly your hands stay clean - I absolutely hate conventional grease guns where you end up covered in the stuff.
https://shop.lrt-lubricants.co.uk/products...grease-gun
Post #945634 13th Mar 2022 2:45pm
discomog
Thanks for the recommendation Grouse. This is just what I was looking for - I particularly like the screw on cartridge and it comes recommended. I'll get one ordered this week. Defender 90XS SW
Morgan Plus 8
Post #945654 13th Mar 2022 5:15pm
Screbble
That does look like it’ll do the job properly and reduce the mess - and not overly expensive either.
Might be worth adding one of these for good measure?
I’ve only got a basic grease gun, and it can be a pain to operate with only two hands Whistle but the locking nozzle helps improve the greasing experience! Thumbs Up
Post #945661 13th Mar 2022 6:22pm
Roy5695
The easiest way I found to cure the air locks is to buy the grease cartridges. Much less mess when it’s empty and needs filling again too. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #945706 13th Mar 2022 10:59pm
discomog
Thanks again to Grouse for his recommendation. Just been using my newly acquired Fuchs grease gun. Just done a grease around on my tractor and a couple of implements. Changing grease cartridges is a doddle, no mess whatsoever and hands completely grease free. First time I've used a two handed gun - so much easier than a single lever. Defender 90XS SW
Morgan Plus 8
Post #946981 25th Mar 2022 12:06pm
Grouse
Thumbs Up They definitely make it so much easier and cleaner.
You can also buy the Fuch / KAJO type cartridges on eBay - various different makes and quantities e.g.
https://www.ebay.co.uk/itm/12-x-500g-LZR-2...635-2958-0
Post #947058 26th Mar 2022 1:11am
srod
I borrowed a battery powered Milwaukee grease gun to do my prop shafts recently. I never would have thought that was a tool that needed electrifying… but WOW!!!
Post #947136 26th Mar 2022 7:51pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I upgraded to the one Gwyn Lewis sells tbe pistol one so I can now deal with the grease job easier. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #947143 26th Mar 2022 9:31pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
I use an air one in the workshop but although I don't own one, I saw a plant mechanic use a Dewalt battery powered one on a hire digger once - I lost a track and summoned help, the track adjusters use grease to tension the tracks back and he just put it on and brrrrrrt done. Better even than air - if I needed one I'd get one without hesitation. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #947492 30th Mar 2022 9:43am
Oldowner
Almost all cartridge grease guns can be manually purged if airlocked but nobody knows how to do it!
You pull the lever at the bottom out and then twist it 90degrees , this then overrides the spring tension and lever can then be manually pushed / forced in to the gun with more force than the spring, which forces trapped air out that the spring alone cannot.
Post #947848 3rd Apr 2022 7:23am
