![]() | Home > Maintenance & Modifications > Panhard polyurethane bushes seem too big?? |
| jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408
There was a change of panhard rods in 2002, which changed to a larger bush/bolt set up, although I don’t know the exact details unfortunately
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2787
The bushes are the same width where they mount in the axle and chassis bracket, only the bolt size changed from M14 to M16. The outer diameter of the later bush is also larger where it sits in the rod ends. As such it’s probably just poor quality polybushes.
Most polybushes are notoriously rubbish, replacing with a set of genuine Metalastik bushes will be a better option. Difference in bushes here for reference: Click image to enlarge |
Should also add that the genuine bush manufacturer changed a few years ago after the end of production so it’s no longer worth getting the genuine ones as the quality is no better. Most suppliers would recommend a superpro poly bush as they are about the best you can get now
| jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403
Yes superpro bushes are the way to go these days. 👍🏻 2002 td5 90 county hardtop
Not heard about a change of manufacturer - I bought a set of genuine panhard rod bushes last year and they were still Metalastik branded. They were date marked 2021 as well so not old stock.
While SuperPro have a better reputation than the cheap and nasty ones, they still have the inherent flaws of polyurethane bushes in that they don’t provide torsional resistance and they allow dirt to sit between the bush and arms and wear them. Whether these issues are a problem for you will very much depend on what you use the vehicle for. |
| I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 886
Retro anaconda has nailed the issue with polybushes.
I ran polypushes (the genuine Polybush products) in the past and got fed up with them suddenly failing catastrophically under extreme use so decided to go back to OEM bushes because at least they fail gradually. When trying to fit the metal sleeved OEM bushes I found the interference fit had gone due to abrasive wear of the polybushes when used in muddy conditions. |
| Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 537
Dont fit poly type bushes to Panhard rods the best option is to enlarge the mounting holes and fit the later 2002 on Panhard rod with genuine bushes not Superpro or any other poly bush
| NineCherries Member Since: 10 Aug 2019 Location: Falkirk Posts: 59
thanks guys,
retroanaconda - thanks for the image, it confirmed what I thought. Mine is the earlier one with M14 bolts and the bent rod to miss the diff pumpkin. i might just have to keep a supply of bushes in the garage and change them as needed. if the "genuine" dealer ones are no better than aftermarket/oem spec then i'm as well having some spare. mine is a daily driver with occasional off road days when i can make it along to them so the worry of polybush grinding away isnt too mush of a worry. at least I know is just a crappy design of polybush ive fitted, but like i said it has improved the steering feel so ill fit a new bush to the original rod at my leisure and get it back on. thanks again folks |
was the mount not beefed up too on the chassis and axle and flipped round too? as I thought the newer style was torqued to over 200 Nm and my old style to 80 odd? Is this what you've done? Cheers T |
The axle bracket is stronger but the late Pan rod can be fitted to earlier axle by opening out the mounting holes to the later bolt size
In an ideal world we’d all fit genuine bushes and live happily ever after.
Unfortunately we don’t live in that world anymore. Firstly genuine bushes are ridiculously expensive. Secondly they are just not reliable anymore. You may get the good original ones that have been on the shelf for a few years, you may not. Some are even paying genuine prices and receiving bushes in a Britpart box. A £6.00 bush for £110 -ouch. Companies like Gywn Lewis have swapped to Superpro for precisely this reason. If you have a source of good genuine bushes , then we’ll done. If you want to take part in the Lottery of hoping to get good ones -fair enough. Personally I have better things to do, so I’ll stick with Superpro from now on , it’s the best of the polys. 2002 td5 90 county hardtop |
If people are paying for a genuine part and it arrives in a Britpart box then they need to change their supplier, regardless of any change in quality of the parts a genuine LR part is just that and is sold/packaged as such. The only exception is where you buy small parts individually which are sold by LR in packs, the retailer will break open these packs to do so and you just have to trust them that you are getting the right bits. For this reason I generally try and buy in LR pack quantities where possible.
I’d still rather fit a lower quality rubber/Metalastik bush than the best polybush for the reasons outlined above, even if that means changing them more often. The panhard rod is the bush that wears fastest in normal use and so I carry a spare rod made up ready to go, which I can swap over in 10 minutes. |
The difficulty comes when britpart run land rover stores and then you get whatever they have to hand, the vast majority of “genuine” parts are now identical to britpart rubbish.
Given that the vast majority of suppliers have gone away from genuine lr bushes over the last few years says it all really, the days of metalastic bushes being better then poly bushes are gone in the past. I would imagine than over the next few years you’ll only be able to get polybushes anyway |
