Home > In Car Electronics > Heated windscreen Wiring
Stiff1
So finally removed whole dash in the 2007 Tdci to replace the seized wiper spindle, more on all that later in another post.
So my heated windscreen was causing an unpleasant electrical burning smell some time ago and while no obvious cause didn't want to spend too much time on it so pulled the fuse.
Now with the dash out the cause is plainly obvious.
So, how/ can I change this connector and is the ceramic (or is it plastic) part available to buy separately?
The negative terminal is unaffected.
Post #945041 8th Mar 2022 12:45pm
Mo Murphy
I had the same thing. I cleaned off the old stuff which had gone soft and put a couple of thicknesses of heat shrink on it. No more burning smell.
Hth
50 Shades of Pennine Grey
Post #945047 8th Mar 2022 1:27pm
If it was ceramic it wouldn't have burned/melted!
Post #945079 8th Mar 2022 6:54pm
Stiff1
Indeed.
Post #945080 8th Mar 2022 7:13pm
It is a salutary reminder that the windscreen draws a hefty current however, and it is worth making sure that the connectors grip really tightly. The source of the heat will have been a poor connection.
Post #945084 8th Mar 2022 7:49pm
