Home > Maintenance & Modifications > LT230 Woes
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
LT230 Woes
Morning all,
I’m struggling with a persistent leak on my LT230.
It’s a fully tricked out box, but has leaked since day one . . .
I had the box pulled before Christmas and Venture 4x4 found the input seal to be leaking. They replaced the seal, but the LT230 was still leaking.
They’ve pulled it again today and, guess what, the input is leaking again.
It’s 100% not the R380. That’s bone dry.
Any ideas as to why the LT230’s input seal keeps failing?
 Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #944905 7th Mar 2022 12:33pm
My suspicions would be a damaged shaft (seal land area), damaged/worn bearings on LT230 input gear, damaged bearings in gearbox, defective seals, or misalignment between the gearbox and LT230.
Is it possible that the seal is being damaged when the transfer box is being fitted? It is easy to damage the seal if you don't use the special long alignment studs.
Post #944906 7th Mar 2022 12:39pm
BaronDefenders
I would hope the LT230 bearings are fine, as it’s a rebuilt box.
The gearbox is quiet, so I’m guessing the bearings are OK. The old LT230 didn’t leak from the input.
It could be duff seals or poor fitting . . .
The shaft looks OK too.
I’m very confused Laughing
 Charlie
2002 Td5 90 (SOLD)
Post #944913 7th Mar 2022 1:02pm
BaronDefenders
The small hole for the dowel in the back of the R380 is slightly out of round. Is there a chance this is the problem?
No idea how long it’s been like that for.
 Charlie
2002 Td5 90 (SOLD)
Post #944937 7th Mar 2022 4:15pm
Dinnu
And the dowel ring is present? See part #37:
https://www.lrworkshop.com/diagrams/land-r...g_53755#37 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944997 8th Mar 2022 1:40am
BaronDefenders
Yes, double and triple checked. The dowels are present.
Everything looks and feels totally normal, except for this dowel hole being slightly oval.
I know dowels can cause problems, but I once had someone fit an LT230 for me and they forgot both dowels! That didn’t leak from the input . . .
Our first port of call is going to be a new seal and put it all back together as perfectly as possible. If it still leaks then, we’ll know it’s likely this hole is the problem and a new R380 will be needed Big Cry Charlie
2002 Td5 90 (SOLD)
Post #945008 8th Mar 2022 9:19am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I can't see the damaged dowel hole causing this, once aligned and torqued up the boxes can't really move in relation to each other anyway.
I'd agree with blackwolf that the seal may be getting damaged during the installation. The oil seal collar looks ok, but may have been installed a little far towards the R380, perhaps it's not making sufficient contact with the input seal on the LT230? I wouldn't assume that the input bearings have been replaced, it depends who rebuilt the box.... It would be worth whipping the input cover off and investigating IMO. Is there any discernible play to the input gear? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #945014 8th Mar 2022 10:01am
BaronDefenders
That’s my thinking. It’s all fairly rigid once aligned.
So you reckon the LT230’s input seal is not in deep enough, or the R380’s output seal?
It was rebuilt by one of the big names in LR gearboxes. They’ve been very accommodating, but until the issue is resolved I think it’s fairer to keep them nameless on the open thread. Charlie
2002 Td5 90 (SOLD)
Post #945023 8th Mar 2022 10:36am
Shroppy
The seal collar is pressed onto the mainshaft of the R380 and the groove in the collar is to enable fitment and removal with the special LR tool. AFAIK the groove should be installed such that the innermost vertical face is inline with the rear face of the R380 (difficult to explain sorry). From your photo it looks as though the collar has be installed a bit further inboard and it is conceivable that the oil seal isn't making sufficient contact with the collar to seal effectively.
Another thought, could the LT230 have been overfilled? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #945026 8th Mar 2022 10:48am
BaronDefenders
Hmmm OK. I shall look into that, thanks Thumbs Up
It has a high capacity sump fitted, so you end up with a total of something like 3.5L to the fill plug. Charlie
2002 Td5 90 (SOLD)
Post #945028 8th Mar 2022 11:08am
landy andy
Assume breather is all clear and working.
Post #945037 8th Mar 2022 12:24pm
BaronDefenders
After replacing the input seal and refitting the LT230, I’ve done 125 miles.
At the moment, we are leak free!
As said by blackwolf first off, it was probably either dodgy or damaged seals causing the issue. Fingers crossed it stays dry . . . Charlie
2002 Td5 90 (SOLD)
Post #945651 13th Mar 2022 4:55pm
BaronDefenders
The leak has returned . . .
I’ve placed an order for a Stage 1 R380 with Winchester as it seems there must be something out of alignment. The LT230 has gone through three genuine input seals, so it can’t just be a seal issue. Charlie
2002 Td5 90 (SOLD)
Post #948049 4th Apr 2022 8:48pm
L110CDL
Hi Charlie
I had this problem a long time ago with a leak on my reconditioned TB, as you described, in kept leaking out and as you have done replacing the seals, we eventually found the leak, the leak was between the outer part of the seal and the TB casing Rolling Eyes , took some time to find, so another TB to replace it from the supplier Very Happy Clayton.
Keeper.
Post #948065 4th Apr 2022 9:25pm
BaronDefenders
I did wonder if that was a possibility, but the leak the last two times was definitely running down from the inner lip of the input seal.
If it continues after a new R380, then the LT230 is going to have to go back.
The R380 has 160,000 miles on it now. It’s perfectly possible there is some wear or damage to the shaft or collar. We know one of the dowel holes is damaged. Charlie
2002 Td5 90 (SOLD)
Post #948073 4th Apr 2022 9:39pm
