Home > Maintenance & Modifications > New Suspension Recommendation Please
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi folks, at 20 years old the original springs on my Td5 110 are getting a bit tired. I’m looking at a full spring/shock replacement in a month or two. So, I’m looking for recommendations please, the details-
2002 Td5 110 CSW
265/16 wheels & tyres
Full set of springs and shocks
Standard height preferred, no lifting or lowering ideally unless sexy pic of your vehicle can persuade me
Vehicle isn’t heavily laden on a regular basis
Hardly ever ‘properly’ off roaded, a bit of gentle green laning occasionally
Tow a horse trailer very occasionally that isn’t nose heavy
Comfort over performance
Budget - definitely less than £1000, preferably circa £500
I’m overwhelmed by the choices chaps, so your advice is gratefully received.
Cheers, Martin.
Post #944743 5th Mar 2022 9:34pm
Dinnu
Very nice Defender Thumbs Up
But what makes you think the springs are tired? Is it sitting lower than you like it to be?
Dampers.. that is possible that need replacement, but sometimes even a set of bushes make a day night difference. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944744 5th Mar 2022 9:38pm
Penfold_6290
Thanks for the complement!
The springs feel soft, we get sway (not worn shock ‘bounce’) and ‘diving’ under braking. The front shocks definitely need replacing, and given that replacing front shocks is such a performance if you’re going to change the springs then that is the time to do it.
I’ve not ruled out doing the bushes too.
Post #944745 5th Mar 2022 9:46pm
Dinnu
Springs have 2 very important parameters:
1. Free length
2. Stiffness
Both can degrade over time, although in my opinion stiffness is less likely to be lost unless there is severe rust reducing the diameter of the wire.
Both would affect the ride height, and from the picture that does not seem to have happened.
For roll, check you still have the front anti roll bar fitted, and its bushes are in good condition.
If nose is diving too much under braking, can check brake balance front/rear. Although a 110 is less affected from cg moving forward under braking compared to a 90 thanks to the longer wheelbase.
Having said that, new shocks would help in both situations if they are nitrogen filled as the gas pressure acts like another spring.
Personally I would change the springs only if they have rusted badly, have really broken, or just want a different ride quality/lift. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944752 5th Mar 2022 10:36pm
Dinnu
Owe, btw, it is always nice to have shiny new parts under a Defender Thumbs Up
I have installed a set of britpart springs under the rear of my 90 as wanted to to have a bit of a softer ride. Been there for about 1 to 1.5 years, but also installed an isolator between the spring and its perch.
They do seem to have sagged a bit since installing. I do not know if the rubber in the isolator that has perished, or the springs have got a new ‘set’ from being loaded. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944754 5th Mar 2022 10:45pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Old man emu shocks and standard springs, give Gwyn Lewis a call, he will totally sort you out and discuss your needs and what suits best.
https://gwynlewis4x4.co.uk/
Post #944755 5th Mar 2022 11:12pm
Penfold_6290
I will do just that Danny, thank you.
Post #944843 6th Mar 2022 7:54pm
mark1200
England 2004 Defender 90 Td5 HT Caledonian Blue
https://gwynlewis4x4.co.uk/ i also recomend gwyn lewis too. He also has a modification to the rear shock top mount so the rear shock is a pin fitting a very good mod. i replaced all my shocks and springs with old man emu kit for about £850 i think but i am very happy with the result,
Post #945165 9th Mar 2022 5:19pm
