Home > Maintenance & Modifications > Steering dampers
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Steering dampers
So, I know strange question but how do you tell if it’s Censored ? With normal shocks I would press them down and wait for it to rebound, don’t think I can do that trick on this damper.
What are the symptoms of it being bad?
I am asking as I have swaped out most of the steering rods/ joints as it’s a 10 year old car and all the boots were missing or broke (will pass a mot/itv in Spain with no boot on the joints no problem) but no record of having that damper changed and you see often people swapping this part, so just wondering if I need to swap it or it’s fine as it is. It’s not hard to compress or expand but it’s not easy, but also first car that I have played with this type of damper on so no idea if it should move at all etc
Thanks in advance Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #944604 4th Mar 2022 6:43pm
Dinnu
I think with a steering damper, you can check if there are any 'blank' spots where there is no resistance, and that no oil has leaked past its seal. Of course check the condition of the rubber bushings.
Having said that, a steering system on a Defender which is in good condition, particularly bearing preload on the swivel housing, the steering damper would actually becomes redundant.
PS. with normal road spring dampers, it is only the nitrogen filled dampers which would extend on their own. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944609 4th Mar 2022 7:07pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Most people in the know advise against nitrogen filled steering dampers.
Gwyn Lewis only sells oil filled - they have no 'rebound' and just rely on the oil to dampen things. Rgds.
Chris
Post #944611 4th Mar 2022 7:19pm
Race.it
Thanks guys, so from that the bushes look fine and did not feel any place where jt changed resistance so will continue to use the one that’s on.
👍🏻👍🏻 Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #944613 4th Mar 2022 7:27pm
