![]() | Home > Puma (Tdci) > 2011 puma 110 rear drive shaft |
Advanced Factors Site Sponsor Member Since: 06 Jun 2013 Location: Southampton Posts: 180 ![]() ![]() ![]() |
Hi Alex.
Please use the link below to our website. https://www.advancedfactors.co.uk/rear-hub...0935-c.asp I'm guessing you will either need part numbers TOB500020 RH SHAFT TOB500030 LH SHAFT RUC105200 FLANGE(S) 571752 GASKET Regards Paul. Paul Redding +44 (0)23 8052 2760 www.advancedfactors.co.uk Site Sponsor for Aftermarket Parts |
Alex123 Member Since: 11 Dec 2020 Location: Argyll Posts: 24 ![]() ![]() ![]() |
Thanks Paul
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 787 ![]() |
It’s worth considering single piece shafts, eliminating one wear point.
I think Britpart are as good as any, but stand to be corrected. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
Do you mean rear prop shaft or rear half shafts? |
Rear prop shaft
Ok thanks |
Sorry I thought you meant half shaft , not prop shaft, please ignore my post🙂
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2501 ![]() ![]() |
Check out Gwyn Lewis offerings as well.
https://gwynlewis4x4.co.uk/?s=Prop&post_type=product |
Shame you are so far away, I have a spare which is surplus to requirements.
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Got mine from Gwyn Lewis. Don’t forget to get a set of UJ nuts & bolts for the front and another for the rear. The front are shorter than the rear. Don’t rely on a LR dealer to get it right. Had a nightmare with Chester dealer as the parts lists they work on state that they are the same when they are not!!
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403 ![]() ![]() ![]() |
Gratuitous picture of one of my gwyn Lewis props.
Not cheap, but I can’t fault them. ![]() Click image to enlarge 2002 td5 90 county hardtop |
