![]() | Home > Maintenance & Modifications > Door alignment |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
And your question (if there is one)?
You need to adjust the door, or possibly replace the hinges. The picture below shows the ex-factory fit of the offside second row door of my DC. ![]() (And they say that the Great Wall of China is the only man-made thing visible from space)! ![]() |
NFIN02 Member Since: 17 Feb 2022 Location: Londonderry Posts: 96 ![]() ![]() ![]() |
School boy question. How do u adjust door????
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
Loosen hinge screws, lift door up to desired position, hold it there and tighten screws.
If it drops right away, either there is too much play in the hinges, or the screws are not tight enough. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2683 ![]() ![]() ![]() |
Plenty of companies out their that will happily charge you plus £100k to put it right........plus other work.
One of mine is slightly off, it closes perfectly fine and doesn't leak so i'm happy to leave it be. |
There is quite some rubbing between the top corner of the door and the HT side panel... to the extent that it has worn the raptor finish. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 536 ![]() |
They did that from new
