Home > Faults & Fixes (L663) > Noise like a squeaky wiper from rear |
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 192 |
I have coil springs suspension but the same squeaking noise.
I hear it when front and/or rear screen heating is on. I guess the steering modules make this noise. But I may be totally wrong here. 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
27th Feb 2022 11:22pm |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 249 |
Think there's been a post or two on here about the door seal squeaking. The fix is to apply silicone grease I believe. Worth a try though even to rule it out.... |
28th Feb 2022 7:26am |
SJT Member Since: 18 Jan 2021 Location: Somerset Posts: 27 |
Yep same here. D200HT so on coils.... Always when cold and sounds like there's a small bird singing.... I've had worse noises but still annoying!..
ps just sold it so someone else has the problem now! D5. Previously 90HT, D4, D4, D4, D2, D1 (3 door V8!) |
28th Feb 2022 8:42am |
Hissinsid Member Since: 10 May 2021 Location: Yorkshire Posts: 30 |
I have literally the exact same thing, it’s done it since delivery. Mines a D300 110 too, air suspension. I’ve not tried to investigate it so can’t help with what it is though! |
28th Feb 2022 8:20pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3750 |
It could be your suspension compressor as that is under the boot floor but inside the car - on cold days first thing in the morning mine sometimes makes a wheezy sigh as it pumps the system back up to pressure after a cold night but once it’s pushed a little air into the system it is silent even after raising the car to normal road height.. The noise isn’t at all loud or a nuisance though and I used to hear it in my 2015 RRSport too. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
28th Feb 2022 8:49pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1756 |
I have the same issue, tried silicone grease whi helped slightly but came across an answer where the problem was traced back to the roof joint:
https://landroverforums.com/forum/2020-def...de-103717/ 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 250D XS |
1st Mar 2022 8:23am |
Al_Ra Member Since: 03 Mar 2021 Location: Oxfordshire Posts: 65 |
@jomara - I saw you post a while back and actually followed it to help with general creakiness. This is different: it's intermittent but regular (like a squeaky wiper) and also sounds a bit like a bird as SJT said. It also happens exactly the same every time I drive from cold so I'm thinking mechanical/electrical rather than general creaks/squeaks.
It's not annoying enough to warrant a dealer trip on its own so I'll add it to the niggle list for a later trip. |
1st Mar 2022 9:14am |
@Al_Ra, funnily enough I also have a list being compiled of all the things I haven't been able to resolve myself. The joy of being part of the Land Rover family.
It sounds like an issue I had with squeaky airbags mounts on a Disco2 but then again with each new model Land Rover go out of their way to create new and wonderful ways to frustrate owners. 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 250D XS |
1st Mar 2022 10:41am |
