Home > Technical > Determining Puma Gearbox oil level??
Page 2 of 2 <12
mse
MK wrote:
Tip
mine was leaking after a couple of km (2000 ish). Tooked it to the dealer and he said the gearbox was with an excess of 1 litre, so the oil started to come out through the breather pipe. God knows why there was so much oil!
Considering the fill process is electronic at the factory thats a great one, i can believe it though Mike
Post #15393 12th Sep 2009 10:03pm
CapeLandy
South Africa
How's this line from the manual
"The transmission is a fill for life unit and no level check is required at service unless a leak is present."
Rolling with laughter Puma 110 - gone
Series III 1973 - going strong
Post #15441 14th Sep 2009 11:52am
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
Atfter 3 years of not checking the oil level your waranty epires the same time as your transmission. Good plan on Land Rovers part. As soon as something goes wrong with the transmission they will say that the gearbox was leaking and you should have checked the level and topped it up. Laughing
Post #15444 14th Sep 2009 3:28pm
spudfan
Ireland
Gearbox oil change at 200.000 miles, transfer box oil change 90.000 miles, differential oil change at 90.000.That is according to the service sheet. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #15748 22nd Sep 2009 1:46pm
mse
I raised this some time ago as a serious issue - some standard components from years past with MASSIVE service lives, that you wouldnt see on a 300tdi.
I know some oils and manufacture processes do increase service life...take the difflock oils double service life at a minimum and i heard of it quadrupling them on gearboxes.
But i think its a real issue. I think there is a case, despite warranty length, that if you follow manufactures guides you could claim outside of warranty - ive heard similar cases, but its probably not easy.
I will likely replace the oils at yr 3 or 4 service... Mike
Post #15760 22nd Sep 2009 7:32pm
Naks
Are you sure? The Service Maintenance Check sheet says renew the Gearbox at 200Kkm and Transfer Case & Front/Rear Axles at 80Kkm.
I'm debating whether to renew the gearbox at 100Kkm and Transfer Case + Front/Rear axles at 40Kkm Confused
Post #49335 22nd Dec 2010 10:27am
MK
Drain and fill up with 2.2 L of 75W-90 GL-4 oil.
I change the diffs and Tbox oils at 20kkm after passing lots of rivers and driving on very dusty conditions.
MK
NB: GL-5 is not better than GL-4. Even the Tbox accepts GL-4 Puma 110" SW
Post #49340 22nd Dec 2010 11:25am
MartinK
Help!
I'm halfway through an early-life fluid change. Engine was easy, but I don't seem to have anthing to fit the GEARBOX OIL FILLER Embarassed
Fortunately I haven't drained the old out yet (I always test the filler before draining).
I thought I had a good selection of tools, incl the TORX (T50 I think?) for R380 gearboxes etc, but nothing seems to fit, and I can't get a good enough look at it to see whether it's hex or Torx. Elsewhere on the forum it says T50, but I thought the R380 was T50, and that's not big enough...
If anyone knows, that would be great, otherwise I'll order a set of each covering the sizes I don't already have!
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #94344 15th Oct 2011 11:47am
MK
Can nt remember really. I ended up replacing both plugs by normal heaxonal brass ones and Al or Cu washers. Much better IMHO. Puma 110" SW
Post #94345 15th Oct 2011 11:51am
MartinK
Quote:
Help!
Bump...anyone know the gearbox filler plug type/size? Someone said it's the same for the filler & drain...but mine isn't Confused
Post #94364 15th Oct 2011 3:07pm
MK
Both in my hands. T50. Puma 110" SW
Post #94368 15th Oct 2011 3:50pm
MartinK
STAR! Thank You! Off to Halfrauds now so I can do this in the morning... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #94369 15th Oct 2011 3:52pm
wslr
The original question about the Castrol BOT oil is interesting. The Freelander2 uses BOT 118 or something like that in the front diff, but you simply can't get it except from the dealer. Perfect if you are out in the middle of beyond... Rolling Eyes
Post #94393 15th Oct 2011 7:14pm
MK
I think all these BOT things are kind of factory fill oils. You just need to know the specs in the web and get an equivalent. Puma 110" SW
Post #94394 15th Oct 2011 7:18pm
wslr
I'm not so sure although I know what you are saying would be common sense.
I'm talking to Castrol at the moment about supply and mentioned the BOT 118 for the Freelander. They mentioned that someone like Fuchs were making the oil for Castrol (work that out...) and Castrol were supplying Land Rover with the BOT for a fixed period contract. They were the ones who said that the BOT is only avalable through the dealer - even Castrol can't supply me with the BOT direct.
This is why you see more and more 'Dealer only' comments next to oil lists, especially on the gearbox/Trans/Final drive side. Even the SAF-XO oil has changed to the Syntrax Longlife recently. Doubt it is just a rebranding.
Post #94398 15th Oct 2011 7:47pm
Page 2 of 2 <12
