![]() | Home > Technical > Defender 90 td5 vibration under load |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Have you tried a different front prop? 02' 110 TD5 Double Cab Rebuild Thread
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2704
Don’t forget the anti roll bars. If original the ball joints will be knackered.
Replaced my front ones last year ( I don’t use the rear arb). My issue occurred when I fitted new dampers, I can only assume that it was a classic case of adding a new part highlighted a weakness down the line. Worth also checking the Panhard rod. With the engine off look at the movement as someone else rocks the steering wheel. If so it’s cheaper to replace the whole thing than pay a garage to replace the bushes. Good luck. |
| Td5.90.2003 Member Since: 29 Oct 2020 Location: Bristol Posts: 7
Not tried a new prop no, it was a cheap one tho I’m sure so mite be worth trying a new genuine one?
Don’t have any anti roll bars on mine, and yes a garage has looked over all the bushes etc found the radius arm bushes were shot but just been replaced and no change!
Thanks for reply’s not sure how to tag names |
I would be very tempted to swap the front propshaft, or at least have a very careful look at the condition of the universal joints. Vibration under load is very unlikely to be suspension related, driveline is more likely. As you say the issue went away with the front prop removed then that would seem a likely suspect.
I wouldn't bother with a genuine one. Gwyn Lewis should be able to sort you one out for a reasonable price. 02' 110 TD5 Double Cab Rebuild Thread |
