Home > Technical > Drive flange bolts
Page 2 of 2 <12
Toplink
Drill out to as big a size as possible(a centre drill helps to start).A bit of heat to kill the thread lock.Then use an easy out or a piece of tool steel (a torx bit hammered in to hole will work).Job done.
Don't try and use a windy hammer to remove these bolts,do it by hand then they don't get hot and snap. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #94295 14th Oct 2011 9:57pm
noworries4x4
My Dad (a research and development engineer) always used to kill Locktite threadlock by freezing with plumbers freeze kit and it snaps and undoes easily with an easy out, use the reverse thread type it does not expand the stud or bolt as much as the square hammer in ones If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #94304 14th Oct 2011 10:55pm
Page 2 of 2 <12
