![]() | Home > Technical > Newbie with clutch issues |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2480 ![]() ![]() ![]() |
Any mods? Puma 110" SW
fluffy01016 Member Since: 14 Oct 2011 Location: Lincoln Posts: 4 ![]() ![]() ![]() |
Apart from a stainless sump guard, the Landy is completely standard. Been driving for 17 years and with work I drive 40k miles a year. Never had a clutch changed in any cars except for one evry year in the Landy ![]() |
What exactly has been the fault with all these clutches - are you saying the plates are wearing out or is it some other failure? Steve.
Is it a Td5 engine? Have you used OE or genuine spare parts?
I assume you changed the pressure plate at some point. Perhaps the double mass flywheel is not good anymore (internal spings), twisted. Out of tolerance crankshaft rear flange? Condition of both (engine and gearbox) input shaft bearings. Std engine and no remap/chip on? Check both propshafts are tuning with no issues and you can truly unlock the central diff (beyond the warning light switches off on the intrument panel). You start to move in 1st and not 2nd gear? Puma 110" SW ............................................................. Earth first. Other planets later |
It's being predoninantly by the wife at the moment and the symptoms she's describing is high biting point on the pedal and slipping clutch when towing. Not sure on the engine and all I can say is that it's a 1993/l with a 2.5tdi engine (no chip). Clutch only fitted in January (found reciept) and was a genuine Landrover part from Rimmer Brothers. Was done as a kit, so yes the pressure plate was done too. The only thing I can think of is that the 2nd gearbox doesn't work properly and will only engage in high range/no diff lock. I thought this fault might be causing the clutch to go? As for the other issues, I can't say but I'll ask my garage to look into them Many thanks for the reply |
Clutches just seem to be wearing very, very quickly. I'm ok with basic engine work and I've checked the master & slave cylinder and both look to be ok. |
Could it be a problem with the flywheel? John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
1993, so is that 300 Tdi?
Could the wrong push rod be fitted? Why is the clutch always biting so high? Pedal not set correct? Andy |
