Home > Puma (Tdci) > Heated Windscreen Switch = No Light
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi all
I have a 2.4 puma and the heated windscreen switch does not light up when pressed so the screen is not de-misting.
Can someone please point me to the fuse (i think its the 30amp in the drivers side dash) to look at and the relays?
Thanks
Nick
Post #942450 14th Feb 2022 2:07pm
The heated screen wiring is a little bit more elaborate than might be expected, and although it can be trouble-shot relatively easily is it not intuitive, and there are several things which can cause problems.
I've taken a screenshot of the 2.4 wiring diagram and uploaded it below, it may help you.
The first check would be that CJB fuses 15 and 36 are intact.
Post #942478 14th Feb 2022 5:11pm
nick.bw
Thank you! will have a look later today!
Post #942481 14th Feb 2022 5:39pm
