Home > Series Land Rovers > Lightweight wheel fitment for not using extension arches
Hufflepuff
My Father has decided that his 2022 project will be to pull his 1971 series IIa lightweight to pieces which we have both shared for the last decade, and 'do it up properly' to make it a bit more presentable, while freshening up the engine which has developed an interesting creaky whine.
As part of this operation he would like to remove the plastic wheel arch extensions and get some new wheels/tyres which will fit without them:
We are struggling to find out what the original wheel fitment would have been for a lightweight, to have a narrow set of tyres on which would fit without the need for the arches. Does anyone happen to know what they would have been? Its on a set of modular type steelies at the moment, but with wider BFG KM2 tyres at the moment which will have to go.
It does have a disc brake conversion at all for corners so its possible a lower offset wheel might not fit around the brakes anyway. 2005 Td5 90 XS
1989 V8 110 CSW
Post #942366 13th Feb 2022 10:03pm
camelman
It would have originally had 5x16 wheels.
Have the whole axles been replaced or just the hubs. If its got 90 axles, they will have a wider track.
Do you happen to have its military reg?
There's a useful Facebook group here https://www.facebook.com/groups/landroverl...?ref=share
Watch out though as there are loads of posts featuring a little red landie with a white stripe Whistle
Post #942372 13th Feb 2022 10:24pm
gcc130
I think the original fitment would have been 6.50 x 16 or 6.00 x 16.
If the disc conversion is an aftermarket one on the series axles it may not be possible to fit standard series swb rims as they will foul the calipers.
As far as I know only the Haystee conversion can use original rims.
I think you need to establish what axles and disc conversion you have first.
Post #942376 13th Feb 2022 10:54pm
camelman
The tyres would have been 6.50x16 but not the wheels, they are 5x16
Post #942377 13th Feb 2022 11:01pm
Hufflepuff
Its on proper lightweight axles, with the Zeus rear-disc brake conversion. I'm not sure which kit was used for the front discs.
Sorry Camelman I don't know its original military reg, I'm not sure if my Father has investigated that or not. I've seen both your green and red and white 1/2 tonners, looking mighty fine Very Happy
OK original wheels would have been 5x16 hmm that might explain why the current wheels stick out. Thanks for the information! 2005 Td5 90 XS
1989 V8 110 CSW
Post #942381 13th Feb 2022 11:13pm
camelman
I'm running 1 ton rims on the green lightweight.
They are 6.50x16 ANR1534 but even with 7.50s, they only protrude slightly from the bodywork.
Sounds like your modulars have a more significant negative offset
Post #942385 13th Feb 2022 11:29pm
camelman
If you want to pm me the chassis number we should be able to gets its mil reg and therefore its service history.
Post #942386 13th Feb 2022 11:30pm
gcc130
Sorry, I was referring to tyre size, not rim size.
The current rims look like wolf rims.
Post #942389 13th Feb 2022 11:53pm
The original tyres would almost certainly have been the legendary Goodyear Xtra-Grip in 6.50x16, the world's loudest tyre. You could hear them coming over half-a-mile away!
You could run 7.50 Michelin XZL on 5.50J16 rims as used on LWBs or standard steel Defender rims, they would not look inappropriate.
Post #942391 14th Feb 2022 12:00am
gcc130
LWB rims won’t fit over Zeus disc conversions.
I run one ton rims on my series one and looked into fitting a disc conversion on the front. As far as I know the only conversion which will accept standard rims is the Hastee kit. On other conversions the calipers are too close to the rim.
Post #942392 14th Feb 2022 12:16am
Ah, I missed the rather significant point that the brakes had been altered. That greatly limits any originality options. I'd be inclined to convert them back to drums.
Post #942400 14th Feb 2022 8:06am
Hufflepuff
I don't think he would be prepared to do that, he likes being able to stop! I will discuss it with him. 2005 Td5 90 XS
1989 V8 110 CSW
Post #942407 14th Feb 2022 9:32am
gcc130
If you keep the existing wolf rims you could use a narrower tyre such as 7.50x16 Michelin xzl and it might just fit under the arches.
Post #942408 14th Feb 2022 9:40am
camelman
If you're just after a tidy up and a usable motor at the end of the day, leaving the discs on is probably the best option but will affect your wheel choice.
Decent Lightweight 2As are fetching good money and the more original the better. If you're going for a full on restoration, it would make sense to put it back to original drums.
I have a friend with a restored 2a and the insurance company have an agreed value of £35k on it!!
Post #942410 14th Feb 2022 9:43am
Hufflepuff
I will discuss it with him. I think the originality aspect has already left the building, other than the galvanized chassis and parabolic springs, after using a fairy overdrive for a few years, he decided to swap in a R380 to make cruising more comfortable. I doubt he will want to reverse that modification.
What he really wants is power steering, but the kits he's looked at seem very expensive. 2005 Td5 90 XS
1989 V8 110 CSW
Post #942414 14th Feb 2022 10:11am
