Home > Puma (Tdci) > 90 SW rear cargo shelves/side cages?
Gasket
Hi everyone.
I'll confess I find the factory rear storage on my 90 station wagon to be fairly useless - there's never more than a driver and passenger, so the rear seats just take up space and rattle/creak annoyingly.
So planning to remove the rear seats and to soundproof the rear tub - creating much more space.
But the space is still a bit awkward with the curvey wheelarch panels.
I noticed that Flatdog does a pair of side cages with a large shelf that goes over the top - thereby squaring-up the rear space. But I'm sure there are alternatives.
I wondered if anyone had any really good examples or tips on how to make this space really usable? I prefer an OEM look (my pet peeve is manufacturers laser-cutting logos into kit) and would want to try an use existing boltholes.
Photos welcome!
Post #941833 9th Feb 2022 8:48pm
jimbo55
What are you wanting the storage for? A drawer system is good for smaller items but obviously is no use for any large item.
The flatdog system you mention is pretty much a copy of the old mantec/lr cage system that was used on the G4 110’s. I’ve never used one so can’t comment on how good they are
I previously had a shelf across the tub with the spare tyre flat underneath it, and found it slightly annoying as was slightly too high to comfortably put stuff on the top. I currently have a couple of wolf boxes for small items, the rest of the items (hi lift, tow bar attachments, etc.) have all ended up having their own specific place which makes use of the awkward spaces as I have an internal roll cage in the back which makes everything 10x more awkward
Post #941838 9th Feb 2022 9:08pm
As Jimbo asks, it really does depend on what you want to store. As a general purpose solution, I made a deck to span between the wheel arches, which gives a nice, wide, flat platform and space under for storage boxes or similar. No drilling required to fit, either. This is in a 110 USW but the principal would also work for a 90, of course:
More details of how it's put together here:
https://www.defender2.net/forum/post839523.html#839523 Darren
Post #941842 9th Feb 2022 9:33pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
We fitted a set of these into the back of my partners 110 (the lad area is about the same size as a 90) and they are great.
The logos are very discreet and the system is flexible in that you can remove the self(s) if needed.
The side areas are great and hold an amazing amount of things, and as they are mesh you can bungie items there as well.
They are easy to fit but I stuck some foam tape under the shelf slots to stop any possible rattling.
As you can see from the photo my partner carries a wide range of items in the cages which would be rattling arround in the boot.
Thumbs Up
 Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #941849 9th Feb 2022 10:04pm
Gasket
Thanks everyone.
its not for any real expedition purposes (thought its nice to dream) its everything from supermarket shopping to carting building material and car parts around.
Currently, the fold up seats just take up too much space and are at risk of damage. With them removed, if the vehicle had 90-degree wheelboxes then I'd just put a deck over, but with their 45-degree sloping sides I see where the cages would come into their own.
I hadn't realised there was a mantec variant. I'll confess a 90-version from mantec would be the dream as I'm a sucker for OEM parts.
Wyvern - your setup looks really neat, is that a Flatdog version?
Similarly, LRA - If I could find a way to square off the sides then a simply piece of trailer board over the top could look really very neat. Yours certainly does.
I've just found this post: https://www.defender2.net/forum/topic39220.html which gives some good pic of the seat removal process. I'm looking at the curved stepped down parts of the wheelboxes and wondering if I could make a length of something (maybe a series of cheaply CNC'd ribs to support a top) to neatly sit in the recess to square it up, while bolting into the redundant seat mounts - thereby allowing me to fit a tray straight across.
Post #941946 10th Feb 2022 2:19pm
Have a look at the pictures in the link that I gave. The rear end of a USW is exactly the same as a SW, with the shaped wheel boxes for seats. Overcoming it was quite easy and enabled a completely flat floor. Darren
Post #941954 10th Feb 2022 3:06pm
Gasket
lovely! In that case, that might well give me the easy approach I had hoped for.
Thank you folks. I'll whip the seats out and will look to find a solution based on the advice above.
Post #941969 10th Feb 2022 6:08pm
wyvern
Those are old Mantec ones bought off a forum member - my partner refurbished them with hematite paint before fitting and they are very robust.
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #941983 10th Feb 2022 7:43pm
