![]() | Home > Puma (Tdci) > PUMA MY2014 junction box battery relay identification |
| Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 842
Are they just the spares? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
| nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 |
yep!
| matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120
As you, I have done many security mods to my 2009 CSW 90.
Door and bonnet hinge security bolts. Pedal lock. Bonnet release guards. I bolted a metal plate under the wing plastic cover. I also added a Lights Left on Buzzer and Hidden Starter switch following the guide from this site. https://www.12voltplanet.co.uk/relay-guide.html The other useful thing to do is route the cable internally from the battery box to relay. |
| ForeignCartographer Member Since: 15 Jul 2021 Location: Scotland Posts: 13
Cheers. I ended up taking them out and realised they weren’t connected to anything. I should have realised by the way they are aligned in order!
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489
Hello
Any advice where to find information about these fuses on a 2013MY? Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124
There should be a sticker on the underside of the seat lid
Also listed in the owner's manual. |
| Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 411
What is fuse F5?
Just saw mine was blown but everything functioning normally. |
F5 is for 13 pin tow socket permanent live.
