![]() | Home > Maintenance & Modifications > Swing Away Spare Carrier on a DCPU tub. Which one and how? |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
You've probably seen this thread with the new ORE Pickup carriers but to add here... https://mailchi.mp/c7c0e71f060a/introducin...d7a6780686 James
| Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5895
Thanks JOW. Nope, not seen them. They’re very nice. If I ever go down that road, could well be the perfect option. Hopefully the price isn’t anywhere close to the pressed stainless steel one though….£1300
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
It looks very nice, but don't imagine cheap
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Ore products are extremely well made and totally recommended
2008 SVX 90 2000 XS TD5 90 |
| The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303
I can attest to the above “ Ore products are extremely well made and totally recommended
Exactly the same experience with ORE's Chief - Chris M Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
| chrismack85 Member Since: 25 Feb 2020 Location: Birmingham Posts: 66
Nope wont be that expensive |
I'll happily test one out
| Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 521
Just to update you all, Chris at ORE decided to redesign his new pickup wheel carrier the week before it's launch because of us
Click image to enlarge https://www.instagram.com/p/CZrBEigMc8c/?utm_medium=copy_link Quite the commitment to his customer base Click image to enlarge Stuart
Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18036
What a hero! Really looking forward to seeing this now.
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Do you have a photo of the arrangement without the tyre? |
| LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886
Ive got the nak one. Lovely piece of kit. Its built like a tank, the welds and powder coating are spot on. It has an extra support to take the weight of the wheel when the door is shut so theres no load on the pivot which also holds it dead still when on tracks. Not a rattle or squeek anywhere.
From a strictly technical point of view I feel the need to reply to this however I sense I’m getting into a debate with a competitor product which I don’t make a habit of doing in the public domain however there’s some very specific things you mentioned technically which I’ve only heard in emails forwarded to me by customers from others sooo…..
We use what are basically wheel bearings (timkin) so there’s no sagging… also serviceable. We considered the plastic bush route but from experience I’ve seen engineering polymers/bushes wear quickly especially in exposed environments (grit/mud/dust) we didn’t like the idea of the need for an extra support as when the bush wears the arm sags and catches on the support in the home position. I’d guess there’s always powdercoating scrapped off there and also the need for the support to be adjustable to move down as the arm sags and the bush wears…. Also the videos of some 16st bald bloke Standing on top of the wheel with the door fully open show how strong our design is. …. For the record I’ve lost a stone after dry January 🤣🤷♂️🍺 Video of a fat bald bloke here Cheers Chris Chief design chimp at ORE Also head of entertainment and chocolate biscuits 🤓 |
Good vid and a nice bit of kit
Ive not expeienced any wear in my plastic bush.
Granted your wheel bearing approach is probably very effective but the naka route is very effective too, both have advantages and disadvantages. I dont see why you should have to shoot down other brands, surely letting customer feedback speak for itself from both companies is what really matters. When i was choosing my carrier i only saw good reports from both brands. Ive not seen the ore bearing set up in person but im sure it has its own flaws. If you get grit,sand and water in wheel bearings you use im sure they dont like it ether and as it wears the bearings will have to be adjusted and tightened to stop rattles and play. |
