Home > Puma (Tdci) > Fuel Economy on 2.4 tdci.
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
What sort of fuel economy are we all getting on our 2.4 tdci’s?
I have a 2011, 2.4, 110 and it seems to be getting worse on fuel. I know you don’t expect a defender to be as frugal as a church mouse, but……..
I de-catted it last summer and it made big difference. It seems to have dropped back. I used to get about 29-30 up to a couple of years ago.
I am getting about 24-25 mpg at the moment. It has 87,000 on the clock.
With the astronomical price of fuel, I was wondering if it was there was anything physically I could do to the car to get it back to where it was?
Map; maf replacement or remap?
Sensible thoughts welcomed.
It runs nice and there is nothing obvious. It seemed slightly flat last time I was out with the trailer on.
Post #941154 5th Feb 2022 7:27pm
LR90XS2011
try the search function on here there are loads of threads about economy DEFENDER 90 TDCI XS,
Post #941155 5th Feb 2022 7:33pm
Dinnu
Tyre pressures? Or perhaps dragging brakes? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #941156 5th Feb 2022 7:34pm
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Sounds a bit low to me; don't think I've ever been below 30mpg but then I don't tow or do lots of 70mpg stints on the motorway Richard
Defender 90 SVX
Post #941157 5th Feb 2022 7:34pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Your numbers don't look completely crazy. I have found that depending on many variables, fuel economy can vary wildly.
My fuel economy is significantly worse on autobahns, where there is a lot of wind, heat, traffic, etc. My worst fuel economy was 13.2 L/100 in Sweden with rain, cold temps, and high winds. My best was 7.8 on Norwegian roads at 80 kph, sheltered by trees, with a moderate temperature and windows down.
Weather (especially wind and temperature) are difficult to overcome. But as an example, a very good result was driving from CH to NO this October, temps in the mid 20s, AC not needed, 235/85 Nokian LT2s at 4.5 bar rear, 2.5 bar front, and the truck loaded to max GVWR. I averaged 9.36L/100 at 110 kph with a BAS 170 tune, and regular diesel. In this case, I suspect the lowered ride height from the max payload offset the increased weight.
I try my best to keep the truck consistent even though it is used in a wide variety of situations and here is what I come up with:
 Roaming around 🇳🇴🇨🇭
Post #941444 7th Feb 2022 6:57pm
Grease prop UJ’s, check tyre pressures and if you don’t already start using Millers diesel additive permanently too. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #941452 7th Feb 2022 7:19pm
Caterham
not sure how much difference it makes but I do wear ballet shoes ( Mr. Green )
I generally work on 500 miles to a tank, anything less and I feel cheated. Anything more I'm happy.
from memory the most I've managed was 615 miles - 40mpg.
BUT - thats trying to be frugal. Thumbs Up
using BP ultimate. Thumbs Up
Post #941875 9th Feb 2022 11:37pm
Mother superior
Yeah, what Caterham said.....Just halve all the numbers Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #941895 10th Feb 2022 9:40am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
600 miles to a tank!!!! wow. I'm normally getting about 420 or so.
Mine's also taken a dip on mpg over the last couple of months. It's going in for an oil change/service next week, so will be interetsting to see if anything obvious is wrong.
I will recheck my tyre pressures ahead of that anyway, but on reading the above am wondering if it's from leaving hte aircon on over the last couple of months to assist in keeping everything demisted.
As to air-con, do people find that using it makes much difference to the mpg in their defender?
In some of my older cars it used to make a noticeable difference, but my last couple of cars (bmw 330d and 5.0 Range rover) it made practically no difference at all - certainly nothing that you could identify consistently. So I'd got into the habit of just using it most of the time.
In case relevant, mine's a 2.2, but imagine the questions/issues here are common to the 2.4.
Post #941899 10th Feb 2022 10:15am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
If your air con compressor is driven off the engine v pulley or serpentine belt you should notice a difference in economy, a modern vehicle air con compressor is electric so much more efficient Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #941906 10th Feb 2022 10:56am
jpboost
All of mine were driven off the pulleys.
That said, the range rover was rather thirsty anyway (12-15mpg) so, proportionately at least, the aircon wasn't really significant!
Post #941916 10th Feb 2022 11:43am
Onemcs
Max I ever get is 400 ish miles to a tank.
It’s remapped and I thought that was good!
Post #941978 10th Feb 2022 7:26pm
I work on 400 miles to the tank as an average, less if towing, and less if a long motorway (or similar road where sustained higher speeds can be maintained) run is involved.
That's a remapped DC usually running around 2.75 tonnes GVW with 255/85 mud tyres and a roofrack.
What really hurts is that at 152 pence per litre it is now £100 to fill the tank, so we've reached the 25p per mile point. Shocked
Post #941987 10th Feb 2022 8:05pm
jpboost
Yes, it really does start to show the real cost of it all.
That said, my L322 range rover was 100litres of unleaded to fill and I only got 220-240 miles to a tank. I miss a few things about that car, but not the fuel!!!
Post #941989 10th Feb 2022 8:16pm
Stacey007
Hello
Over the 6 years or so with ours it seems to do between 29 / 35 with an average of around 32mpg
best I think was around 38 mpg.
Seems to do the same full of camping stuff / bike etc than it does empty.
Its a 110 remapped.
Most of my driving is A / B Roads a though big European trips also (at 75 / 80) it does around 26... but on the toll roads abroad you want to get to places.
In the UK I tend to cruise at 60mph even on the motorways.
Post #942188 12th Feb 2022 4:55pm
