Home > Maintenance & Modifications > to replace 6 month old slave cylinder or not? tdci
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
goodday gentlemen
I have a new clutch and slave cylinder that I installed in August. I am now going to replace the clutch disc and pressure plate again - is there any reason to also replace the slave cylinder considering that is it practically new?
cheers
ds Roaming around 🇳🇴🇨🇭
Post #941384 7th Feb 2022 11:09am
Dinnu
In normal circumstances on a Puma, the clutch fails before the slave starts leaking. Or is not the case? Most complaints I read are failed clutches... 2nd is leaking rear crankshaft seal. If I am correct, then I would be tempted to save the hassle of replacing it at 6months. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #941392 7th Feb 2022 12:13pm
Angus_Beef
The only slave cylinder i can recall leaking was Grenadier's but that was a brand new one and probably a defect. One would normally replace the slave with the clutch for convenience, but in this case I think I'll leave it in place. Unless I get a good reason not to... Roaming around 🇳🇴🇨🇭
Post #941405 7th Feb 2022 3:45pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Mine went on a 2.2 puma after 70k miles - the clutch was ok but the slave cylinder failed.
I was lucky as the vehicle was under warranty and on examination the clutch had some loose springs so they changed the clutch, drive shaft and slave all at the same time.
Just fitted a new clutch and master, slave and drive shaft as an upgrade for overlanding some time in the not so distant future.
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #941415 7th Feb 2022 4:19pm
Personally I wouldn't bother if it is that new, it is pot luck. You could be really unlucky and it fails the day after you put it all back together, but if you put a new one in you could be really unlucky and that also fails the following day.
Generally Puma slave cylinders are not particularly unreliable. The first time I changed my clutch I fitted a new one, the second time I didn't bother. That cylinder (and for that matter the standard genuine parts clutch I fitted at the time) have now done 120k miles, about the same distance that the four previous clutches did in total. I do need to put another new one in soon (I've been saying that for quite some time now) and will be changing the s/c this time, since at 120k it has done enough for me to feel it owes me nothing.
If nothing else my vehicle provides an insight into how the standard clutch has improved: the first 130k miles got through four clutches, the last 120k miles has been done on one. The next clutch (already waiting to go in) will be a 4x4 Transit one.
Post #941454 7th Feb 2022 7:19pm
^^^^ Just like my Td5... when I changed the flywheel, the crank oil seal was bone dry, but I thought "I'll change it as I'm in here"
2 days later its leaking like a seive Rolling Eyes
Post #941462 7th Feb 2022 7:47pm
Angus_Beef
blackwolf wrote:
... how the standard clutch has improved: the first 130k miles got through four clutches, the last 120k miles has been done on one. The next clutch (already waiting to go in) will be a 4x4 Transit one.
The standard clutch in my Jan 2015 build was quite good until 56,000 miles when a spring fell out. Mitigating circumstances are that twice in those 6 years I accidentally stalled the truck - the second time I simply lifted my foot from the clutch pedal thinking it was in neutral, when it wasn't. User error for sure. The clutch was "different" and after that a spring fell out within 18 months. This strikes me as unusual and has me steered away from another LR spec clutch. The SACHS 3000.950.727 "dgardel special" is next.
Come to Norway and we can have a clutch party weekend with steaks and adult libations Thumbs Up Roaming around 🇳🇴🇨🇭
Post #941467 7th Feb 2022 8:16pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
If it’s not that old and you don’t think it has an issue, I wouldn’t see any requirement to routinely change it. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #941473 7th Feb 2022 8:37pm
