![]() | Home > Puma (Tdci) > Tdci instrument cluster stopped working |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
Right if the alarm LED is operating, the permanent supply is OK.
If some warning lights [hazard/unlock direction indicators] work then the ground is OK. This points at the ignition supply. Fuse 4P in the fuse box on the bulkhead (under the steering wheel) is where the ignition supply comes from, it also feeds:
Are these working or not working? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| Jiiim Member Since: 21 Jun 2016 Location: Ea Posts: 12 |
Nice one! Had completely forgotten about those and had only checked the ones under the seat
F4 was intact - but removing and reinserting seems to have sorted things (F5 is missing - don’t know what that’s for?) Maybe time to put some electric grease on all the fuses ! Thanks again! Jim |
Great stuff
Fuse 5P isn't used, nothing to worry about there 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
The orientation of the fuses mounted in that fuse box in that manner is asking for high resistance issues and loose fuses. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 256
Click image to enlarge I've got the same problem, all fuses intact, have indicators and backlights on dash but no symbols like glow plugs or battery light. I've taken out all the fuses to check them. Tried disconnecting the battery still no joy. I have rear window wiper and spray. No rear window heater. Not registering, revs, speed or fuel and temperature, doesn't record mileage either. I've followed Martin's advice above. Any help appreciated.
Heated rear screen switch Not working Heated front screen timer Don't think I have this Headlamp ignition control relay Lights are working Ignition feed relay for: electric windows, heated seats, rear washer, rear wiper relay[color=red] electric windows not working now, but have rear wash and wiper.[/color] |
2.4 or 2.2?
2015 D90 XS SW |
2.4 2007 TDCI[/i]
I would have said Fuse 15 is the common fuse for all of these, but you say your headlights do work.
Worth a check of that anyway... 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks, I'll try replacing the fuses with new ones just in case.
I'd bought a bumper box of fuses just in case but only needed a 5 and a 10 amp. Cheers, Craig |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Something on similar lines. 2.4 Puma. Reversing light stopped working. Checked bulb and fuse both O.K.so I changed the reverse switch, still no reverse light. So to double check I changed the bulb and the fuse and still no reverse light. 1982 88" 2.25 diesel
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2540
Is your reverse light switch being activated by the gearbox ? worth testing with a meter. There was a topic on here where the arm in the gearbox was worn and not depressing the reverse switch, so discounting that is a good start to localising the fault. Then work back from there checking wire continuity including earth and bulb holder. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18036
Not long after I bought my Puma the reversing lights packed up and it turned out that this was because the switch was not screwed fully home in the gearbox. It was, at least, an easy fix, but one which would have been cheaper had I not already bought a new switch.
| CrisEverett1975 Member Since: 26 Aug 2022 Location: High Wycombe Posts: 11
Hi, I've got the same issue. Instrument cluster is dead, no rev counter, no speedo, Fuel, temperature etc.
Lights & indicators work, rear heater works everything else seems ok other than the instrument cluster. |
