![]() | Home > Puma (Tdci) > Random Electrics |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 597 ![]() ![]() ![]() |
There's an earth cable in the driver's side wheel arch to the chassis. No idea if that's the issue but it's easy to check.
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 632 ![]() |
I had the exact same issue a few weeks ago after the car had been in for some work.
Turned out the negative battery lead had come off the terminal and it was only the spring-back of the cable that was holding the cable against the terminal. Followed an excellent tip from the forum to use some copper shim around the battery terminal to allow the clamp to really take hold. That fixed it. |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378 ![]() ![]() ![]() |
My backlights come on/off/flicker as I rotate the heater output direction control around. I've not had a look yet, but whatever the bad connection is, it is definitely local to that area. So don't rule out something in or close to the panel.
Sorry, no answer for you, but I'll come back and update when I get a chance to pull it apart and investigate. |
James Weston Member Since: 01 Feb 2022 Location: Staffordshire Posts: 8 ![]() ![]() ![]() |
Just taken all earths off the bulkhead under the bonnet and cleaned them. Still no better.
Ran out of daylight so will see what I can find at the weekend. Also, what is the green box(ECU) that is next to the fuses under the dash? There is an orange with grey striped wire not connected in the plug |
That's the AS10 alarm unit. Darren
Thanks for letting me know, I will see if I can fine where the wire is supposed to connect to know.
UPDATE on the Orange wire from the ECU...... It isn't supposed to be connected as it is acting as an Aerial But still no further on with the other electrical gremlins ![]() Last edited by James Weston on 4th Feb 2022 8:04am. Edited 1 time in total |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6703 ![]() ![]() ![]() |
It doesn’t attach it’s the aerial.
