- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Gasket
Mudflap bracket to crossmember bolt size? | |
Hi folks.
I've just come to refit my rear factory mudflaps and have lost the fasteners. So may as well fit stainless.
The part number for the bolts (FS106167L) corresponds to a M6 * 16mm flanged hex screw which I have found in stainless - these attached with a standard washer and a spring washer which I also have in A2 M6. But noticed that YRM and others supply 20 or 25mm fasteners with their brackets.
Any reason to think that 16mm would be too short (eg: parts catalogue error)? or if its an open rivnut in the crossmember, an harm in upping to 20mm to be certain?
Thank you.
28th Jan 2022 6:15pm |
geobloke
Nope no reason why increasing the thread length by 4mm would have any negative effect. As far as YRM etal are concerned 20 and 25mm thread lengths are just easier to supply and no-one is ever going to complain about having too much thread, but folks will be severely irritated if they find the bolts are 4mm too short
Whatever you choose just make sure you anti-seize the threads
28th Jan 2022 7:20pm |
Gasket
Lovely - thank you very much.
30th Jan 2022 5:51pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
