![]() | Home > Puma (Tdci) > TDCI instrument clusters |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2428 ![]() ![]() |
As the last defenders had dynamic stability control added I’m wondering if the cluster was modified to account for that (is there a light that comes up on the cluster if activated ? mine is an earlier 2.2 so I don’t know ) hence the different part number and potentially incompatibility with the earlier 2.2 models that don’t have it.
Topvaruk Member Since: 25 Apr 2018 Location: bratislava Posts: 69 ![]() ![]() ![]() |
Thanks for the prompt reply
I am beginning to think the same. Pins missing from the steering wheel also which ties in with that idea Lockwood card kit is probably where I am going Thanks again |
I would contact Martin, site admin on here, he will very likely know the exact issue and if it can be addressed with a mod to the km cluster you purchased.
https://www.defender2.net/forum/member-martin.html Last edited by Ianh on 29th Jan 2022 4:20pm. Edited 1 time in total |
Will do
Many thanks |
