![]() | Home > Td5 > Clutch Spring |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408 ![]() ![]() |
It feels strange just based on it being so different to what you are used to, I found the same when I fitted mine a few years ago. I still have mine fitted, but to be honest I’m not sure I’m convinced by it
A lot of people say the same thing when first fitted, just because it's so different from before. Give it a few days. Darren
phillips321 Member Since: 16 Dec 2021 Location: UK Posts: 103 ![]() ![]() |
Get used to it, it'll save you knee!
I have one, TBH I didn't actually notice any difference. It came with my kit from LOF and I didn't realise I had been driving around without one before.
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
My left knee is F****d, without the LOF spring the Fender would be a problem for me… Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 400 ![]() ![]() ![]() |
I hated the feel of ours at first but within a few days it either a) freed up a bit or b) I got used to it. Overall it was much lighter than the standard spring and despite being a right bar-steward to fit I have no regrets.
I had to raise the pedal height to get the clutch bite point right (due to a new master cylinder fitted at the same time, not the spring) and it felt like the spring had to overcome some initial inertia at the top of the stroke but now it's as smooth as silk. I have a Power Slave from L.O.F. to go in at some point, I have high hopes of that. M |
There is another option. Replace the original spring and fit either the LOF master or slave cylinder. The pedal will still be lighter, much lighter, but more familiar in feel.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 993 ![]() ![]() ![]() |
Just keep driving you’ll get used to it quickly. It is definitely very different that OEM. I have also
![]() Stick with it. 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
djam1 Member Since: 30 Apr 2012 Location: Northwest Western Australia Posts: 3 ![]() ![]() |
Thanks for telling us about it I have been wondering myself if I should go down this path
cocker Member Since: 23 Sep 2021 Location: Merseyside Posts: 38 ![]() ![]() |
Getting use to it now but still fells strange
Paulo RB Member Since: 16 Mar 2021 Location: Wirral Island Posts: 11 ![]() ![]() ![]() |
Whew, I thought it was me, getting used to mine now, great things Paul RB
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3375 ![]() ![]() |
l've had the assist spring fitted for years, l am used to it but because of the way that it works, it's harder to bring the clutch up smoothly in first gear or low range.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2391 ![]() ![]() ![]() |
I've had a Land Rover spring on my clutch pedal for years to good effect. I also have a lof spring in the box from my last clutch change. Would I notice the difference if I swapped the LR spring for the lof version ?
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
I gave up trying to fit my LOF spring
