Home > Technical > Axle breather, replacing banjo with the later 'push fit'
Dinnu
Gents, followup to Recall Action P047/048, also discussed: https://www.defender2.net/forum/topic33029-180.html I got a Discovery 1, 1994 or later front axle tube, as much cheaper than trying to get the brackets done by JLR.
One thing I like to do to this axle is covert it from the banjo to the push fit breather connection, FTC5085.
Probably some would argue why, cause the banjo design is so much better, but I like to keep it true to its design Surprised .
Wondering if anyone has done this before, and if it was just a matter of widening the existing breather thread to accept (which seems to be a press fit installation) FTC5085. Or if the push fit adaptor will fall through the existing breather threaded hole. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #939496 25th Jan 2022 7:30pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
FTC5085 is a hateful thing IMO, you are far better off fitting a 90 degree push fit union of the appropriate thread such as this - ebay.co.uk/itm/133168923086
As for fitting size, the replacement axle casing you have should be 1/8 BSP, the Puma axle casings have an unthreaded hole of approx. 10mm. On my post 2002 110/130 rear axle casing I chose to enlarge this to 11.8mm and tapped a 1/4 BSP thread for which there are many hydraulic/pneumatic fittings. I believe I opted for 6mm hose to match that of the original. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #939508 25th Jan 2022 8:43pm
Dinnu
Thank you Shroppy for your input. I did hear/read quite a bit of negative feedback on the push fit connectors. I do not have enough experience with these adaptors as an axle breather, but use similar connection designs on pneumatic systems, and can count the failures on one hand in the last 23 years.
What exactly are the problems with these adaptors? The only thing I can think of is dirt getting into the release mechanism of the adaptor, maybe can erode the locking barb inside.. what else could go wrong? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #939537 26th Jan 2022 7:16am
Shroppy
Apologies Dinnu, I think I may have confused matters somewhat.
The push fit pneumatic fittings are on the whole excellent in my experience and I would have no concern fitting the 90 degree adaptor I linked above to any axle casings in the future. In fact, I'm using the same push fit connectors on my gearbox and transferbox for simplicity. You can see them in this photo:
My dislike for the LR fitted FTC5085 is due to the routing of the breather hose, it exits the casing vertically before bending back towards the casing making it susceptible to being ripped out. The retaining mechanism is also rather poor and can work loose.
Hope this clarifies things Thumbs Up 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #939539 26th Jan 2022 7:54am
Dinnu
Thanks Shroppy, That clarifies a lot. I do not use the Defender as it should be used, so not too worried about being ripped out.
Edit. And that TC looks beatiful.. as the rest of the Cummins/130 build Thumbs Up
Been in a Dodge 3500 Cummins powered that sounded fantastic. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #939579 26th Jan 2022 2:34pm
I have to say that I don't like the standard Puma axle fittings, and I believe that one cost me an ATB when it leaked (I have a raised breather but still managed to get a rear axle full of muddy water).
I have no problem with the standard industrial push-fit fittings (the kind which usually have a blue plastic collar) especially when fitted with the optional locking clips, but it is the security and leak-worthiness of the standard fitting in the axle tube which I don't like.
Tapping my axle tubes to take threaded fittings is near the top of my "to do" list. It is one area where "value engineering" has definitely reduced the quality of the product - the old screw fittings were better.
Post #939601 26th Jan 2022 5:55pm
Dinnu
Hmmm, food for thought.
The axle case came with the banjo fitting including the complete breather pipe.. so then might as well let the banjo stay.
It is just that I like originality, and the look of being untampered/unmolested, although the axle prefix number will still give away that it was under a Discovery once upon a time Whistle
But I will have peace of mind that no hubs will part. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #939603 26th Jan 2022 6:03pm
Shroppy
Thanks Dinnu, the gearbox and transferbox have been a labour of love!
Think you may have me confused with Stuart, my 130 build is the V8 one, though I really must update the thread! 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #939635 26th Jan 2022 8:57pm
Dinnu
Embarassed Trying to follow every build 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #939644 26th Jan 2022 9:36pm
