![]() | Home > Puma (Tdci) > Need help with my 07 defender 90 yet again! Thank you |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
Cannot help with your starting problem, but I think that loose wire (orange?) is the aerial for the central locking/ key fob.
Hopefully more experienced help will be along soon. |
It's quite possibly the ignition switch on the end of the barrel. I swapped mine recently due to exactly the same symptoms and there have been a few other people with similar issues.
You can read about mine here: https://www.defender2.net/forum/post933318.html#933318 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Nick13 Member Since: 18 Oct 2021 Location: Kilkenny Posts: 13 ![]() ![]() ![]() |
Thank you guys for the replies! Landroveranorak , the connections at the back of the switch looks fine thou!?? If the barrel was faulty would the battery light stay on??
It depends on the nature of the failure, I guess. I think the battery light would stay on as it only goes off when current is drawn by the starter motor, which isn't happening if the switch isn't working. Darren
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
If nothing except the battery light is on (and your coolant gauge at max hot), then your ECU is off, or the CAN bus is broken.
The above is the default the cluster shows when it has no CAN messages arriving. ![]() ![]() |
Loose wire is alarm aerial - nothing to be concerned about.
