Home > Puma (Tdci) > Rear Shock replacement
Sparky018
England 2010 Defender 90 Puma 2.4 HT Zermatt Silver
Hi Guys, New to this forum.
I would like to know if it is advised to remove the bush locators from my rear axle when fitting after market shocks?
Post #938552 20th Jan 2022 7:09pm
geobloke
It is not necessary. Only reasons to do it are for potentially extra articulation or if the aftermarket bushes are too big for the axle cups.
Your choice. Thumbs Up
Post #938553 20th Jan 2022 7:18pm
Sparky018
The bushes are not to big, just seen others have removed them.
Post #938554 20th Jan 2022 7:20pm
geobloke
The cups are there to provide a first line of defence against dirt and stones. Folks who are looking for max articulation need to remove the cups as they will pinch on the bushes. Standard length shocks will not get pinched.
Post #938555 20th Jan 2022 7:26pm
kenzle8a
I kept mine when I did my Bilsteins and haven't had any issues.
Post #938562 20th Jan 2022 7:50pm
Co1
Kept mine on for Fox 2.0. No issues.
Post #938614 21st Jan 2022 6:55am
markb110
Took mine off
All depends on the travel you want and what you will be doing with your truck.
+5” OME.
Have fun.. Thumbs Up
Post #938650 21st Jan 2022 12:03pm
UtilityTruck
I also had to remove mine fitting the Fox 2.5" units as the bushes are too large to fit in the cups. Straight forward to remove them and I've not suffered any issues from doing so. If you can keep them, I would however. 2014 Keswick Utility 2.2
Post #940501 1st Feb 2022 1:19pm
