Home > Puma (Tdci) > Bubbles in coolant... Oh dear...
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi folks, have been experiencing slight coolant loss for some time. Found and fixed more than a few leaks, but it still persists. I have sniff tested ages ago and it came back negative. Thing is, I am usually working on my own, and today with a friend applying light throttle I could see an increase in bubbling. Honestly it looks like a blow at the head gasket. Is there anything else that might cause this? It is running so well, plenty of power, decent fuel economy.... oh dear.
Post #938249 18th Jan 2022 10:50pm
Ianh
EGR cooler leak ?
Post #938259 19th Jan 2022 2:17am
Moffett
Symptoms are the same I believe? But cannot find much on it?
Post #938275 19th Jan 2022 9:25am
dorsetsmith
clamp and remove coolant hose on EGR cooler and check again Idea
Post #938277 19th Jan 2022 9:29am
Moffett
Sniff tested again and all comes up clear. I will isolate the egr cooler later on. Sounds like a good shout.
Post #938311 19th Jan 2022 12:30pm
Ianh
Did you locate the issue, was it the EGR cooler?
Post #943219 21st Feb 2022 1:13am
Moffett
Check back in two weeks and I will update the thread. I have ordered an egr cooler. I have spoken to a mechanic who reckons he had seen more headgaskets changed on transits needlessly because of the egr cooler. Another who works at Ford reckons the sniff test won't show up a small headgasket leak.That blick tester has never been wrong in the past. I almost wish it wasn't running so well. I won't tackle the headgasket, last one I did was 20 years ago on an E36 Beemer and I never really trusted it after! I do less and less work for myself the older I get. I have a restoration project, and found myself at the land rover more ifyrn rgan it! Local lad who work's on Defenders (but doesn't really like anything post td5) has agreed to take it on, but is telling me 'don't fix it, if it ain't broken'....
Post #943264 21st Feb 2022 12:23pm
Ianh
Post #943369 21st Feb 2022 9:53pm
