Home > Maintenance & Modifications > 1993 Defender brake pipe - what tools and parts are require
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
 I am going to change my front brake calipers on my 1993 defender with 200tdi axles, and I require advice on the tools and parts I need, so could you help with the following please;
Firstly,  what size brake pipe spanner do I need?
Second,  what size brake pipe do I need and what length.  How many fittings will I  need. Does anyone have a link to a reasonably priced decent set.
Third, any advice on a flaring tool for the pipe. If they are a reasonable price I may buy one, otherwise I may try to borrow one as how often should I need it?
And finally,  flexible brake hoses. The original ones don't seem too expensive but I have also seen the braided ones. What would you recommend? Are the braided ones better and worth the extra cash. If the braided, a link to reasonably priced ones would be helpful.
As always, your help and advice is appreciated.
Mick
PS - I am looking to change the brake lines as I suspect they may well brake when removing them as they are quite crusty!!
Post #938124 18th Jan 2022 3:55am
