![]() | Home > Puma (Tdci) > Changing 2.2 puma oil at home? |
| Gaz Member Since: 18 Jan 2015 Location: Midlands Posts: 34
Excellent article at the top of this page by MartinK,Easy peasy 15min job.Just make sure you have a large enough container for the old oil.Good luck
| RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115
Just done mine for the first time. Very straight-forward using the guide in this forum. Just make sure you have a decent 6 sided 27mm socket for the oil filter plastic holder (if that is the one you have - later models have a spin-on canister filter).
I tried using a 12-point socket and the wheel brace and neither was a good enough fit to undo the holder. I bought this socket. http://www.ebay.co.uk/itm/361190858336?_tr...EBIDX%3AIT |
Another thought in case you are not aware.......
For the engine equipped with DPF, oil needs to be 5W-30 to spec. Ford M2C934-B (low SAPS). Opie oils has several. I selected Millers XF Longlife C1 5W-30 Synthetic. My owners manual just says it needs to be 5W-30, but it must be low SAPS. |
| R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265
And if it's a late model 2.2 then you have a spin on cartridge filter which is FoMoCo branded. Pop into
Your ford dealer for the pressed steel socket that fits it. Mine was extremely tight. This tool makes removal easy. Get a big catch tray for the old oil. When you remove the sump plug it comes out about two foot before dropping. After your first of oil change you will see what I mean |
| milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873
I do mine at 6K miles in-between dealer servicing at 12K.
There are a couple of LR dealers on eBay where you can buy a genuine filter and Euro Car Parts is normally the cheapest place for eight litres of Castrol oil with free delivery. Do be ready to catch the oil coming out though. It shoots out a lot further back than you expect! |
| AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242
Get the catch can in the wrong place the first time you do an oil change and you won't do it again.
Then just move the catch can further to the front of the vehicle as the oil spout drops. Then if it's an older 2.4 with the stupid cartridge oil filter you can then have the pleasure of trying to catch the oil from that. All good fun so I'm told and lets you see what the underside is like and teaches you little things about your vehicle. AlanH. |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
Discovered this last week Warm and horizontal oil straight towards my face! |
| Swerni Member Since: 05 Sep 2021 Location: Surrey Posts: 13
Why didn’t I read this before I did my oil change yesterday?
At least I’m managed to jet wash the spillage off the drive |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3787
I can’t remember who told me about this, but it was someone one here: when removing the cartridge filter, wrap it in a plastic bag first and the bag will catch all the wayward oil, leaving your sleeve oil free! |
| Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 371
Under bed storage box widely available for about a fiver, just about the right length and width to catch the spills.
Click image to enlarge It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18051
If you fit a Femco drainplug you can attach a hose to it and avoid mess altogether. Excellent products.
| SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296
Glad I wasn't the only one |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3653
Puma drain plug is M14x1.5 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 243
You can pick up one of these for about 20 quid, I've had the same one for years makes life alot easier.
Click image to enlarge |
| All times are GMT |
