Home > Maintenance & Modifications > Dropped a nut :-(
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Dropped a nut :-(
Noticed wing mirrors a bit wobbly to wiped the door hinge bolts out and loctited the mirror bolts... went to re attach door hinge and dropped a nut which has now vanished into thin air. Should have dropped into the drivers footwell or at very worse into door. No sign of it anywhere.... Any Ideas? anything magnetic that could have caught it?
Will go get anther later, but this one is def in the car somewhere
Post #937840 15th Jan 2022 2:04pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
The nuts normally drop into the bottom of box steel and difficult to recover.
You need a few of these?
MRC2178 Land Rover Defender Bulkhead Captive Door Hinge Screw Nut UNF 90 110 130 On eBay?
Post #937841 15th Jan 2022 2:41pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I did the same today, fiddly little things! Eventually found mine, but a real pain having to take the door card off looking for it.
Post #937869 15th Jan 2022 7:27pm
Roy5695
Usually just pry the bottom of the door card away and they fall out the bottom. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #937877 15th Jan 2022 8:05pm
balmybaldwin
Door card is already out... no sign of the little Censored .
I've bought some more now, but don't really want to leave a random nut loose somewhere.
@matchap - Fortunately it's the nuts on the inside of the door end of the hinge, not the bulkhead ones.... although I have a trick for those:
Post #937891 15th Jan 2022 11:05pm
Dinnu
Assuming you have 2002 door, the bottom channel has some drain holes, but unsure if an M8 nut can go through. If it does, then it will get trapped in the bottom channel, as the lower most 3 drain holes behind the rubber seal are very small. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #937897 16th Jan 2022 4:22am
