Home > Puma (Tdci) > Puma 2.2 front driving lights is there a connector on loom?
camel 110
Hi, Puma 2.2 want to fit extra lights to front is there already a connector on the loom
a. for lights
b. for switch.?
Thank you.
Post #937408 12th Jan 2022 9:18pm
Roy5695
No…
And,
No…
Thumbs Up 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #937414 12th Jan 2022 9:38pm
LR90XS2011
there is however a LR auxlight loom and switch available that makes life simple to install driving lights, or at least there was for the 2.4 as I used it for my spot lights
and loads of aftermarket ones
https://www.defender2.net/forum/post645026.html
https://www.google.co.uk/url?sa=t&rct=...I6jlRtioKA
https://www.mobilecentre.co.uk/defender-au...htbar-loom DEFENDER 90 TDCI XS,
Post #937427 12th Jan 2022 10:44pm
dorsetsmith
If contacted duck worth parts vie PM or email defender2..net discounts are available
https://www.duckworthparts.co.uk/landrover...itlr006815
I used Robin.Hall@duckworth.co.uk
Post #937498 13th Jan 2022 11:17am
hank
Any idea of a part number for this? Can't find it on lrworkshop > 110 XS Double Cab
Post #937503 13th Jan 2022 12:08pm
LR90XS2011
Have searched the net myself and cant find it as a separate item, I got mine off ebay years ago so it could have been part of the full kit.
Below is a link to the kit and the instructions for fitting it.
https://www.lrworkshop.com/parts/LR006815
I would add in LR fashion the cable ratings were the minimum required for 2 x 55W lamps, if I were to do it again I would buy an after market version with larger cable sizing less volt drop and bigger Wattage lamps.
Will go have a rummage in my bits box just in case I still have the packaging with a part number but frankly unlikely as I did my lights probably 9yrs ago DEFENDER 90 TDCI XS,
Post #937567 13th Jan 2022 6:24pm
