![]() | Home > Puma (Tdci) > Battery how big/small (or medium) can it be? |
I’m not hot on electrical systems. Just wondering what is the smallest physical battery the Puma can use? Mine is massive (and maybe dead) but by chance I was watching a YouTube video last week and noticed the twin underseat battery set up many on here have done, but the batteries looked quite a bit smaller. No way my battery (a Varta something or other) would fit at 90 degrees to the seat and this version had two. So what’s the smallest physical battery a Puma can have? Can it have a smaller output as well? I’m not running anything off it, although I may add some LED spots to the roof rack at some point, but heavy draw I don’t think I will in the near future and if I did I’d add a second in the DC’s tub. Any thoughts? Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
The gel batteries are smaller and can be mounted in any orientation, but costly. I run one, and now run two of them. On previous Defs I’ve had split charge, but I don’t require that now so just run two of them permanently joined.
https://www.tayna.co.uk/car-batteries/odyssey/ |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 300 ![]() ![]() ![]() |
A member was thinking of using a pair of NOCO lithium batteries
Might be worth contacting "mediamab" (sorry I don't know how to make a link to a member ![]() https://www.defender2.net/forum/topic81364.html Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
I had the battery dilemma, purely cost related as locally batteries are expensive.
https://www.defender2.net/forum/topic74711.html One remark from a forum member... the ecu still needs power/voltage during cranking.. so keep that in mind. A few LEDs will not draw too much current, nothing compared to a current hungry motor. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
I managed to fit the original Puma battery (LR badged Varta) as well as a Numax CXV30HMF.
Made my own battery tray to do this - was a bit of a squeeze but it fit in the original under-seat area |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1858 ![]() ![]() ![]() |
https://www.power-manutention.fr/avis/batt...es-l5d-455
Heavy duty, standard size, fits perfectly, less than 100E delivered! |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
Me too: original Varta 90 Ah + Ective EDC 100Ah. The tray needs to lift them up, then they fit in. https://kraxlr.de/makingof.html#electrics Both are the same size. Height is important. 353 (L) x 175 (W) x 190 (H) mm I've seen a setup with 240mm height for the aux battery, but don't think there was a proper tray. Looked dodgy. |
Mago Member Since: 25 Apr 2021 Location: Frankfurt Posts: 41 ![]() ![]() |
I´ve fitted 2x Banner Running Bull AGM 92Ah. It is a little tight but fits pretty well. You´ll need a custom made holding system. Size of the batteries is 353 x 175 x 190 mm - H8 DIN (L x B x H)
A buddy drives around with a single 80Ah AGM, without any problems. Greetings ![]() Defender 110 Puma 2.4 |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
110 Amps from John Deere.
Always on stock for their harvesters. Just go there and buy one. The height is near the limit of the box. A perfect fit. However thé auxiliary battery is an AGM battery The smallest solution I use to start my engine has the size of a chocolate bar https://www.walmart.com/ip/Cal-Van-Tools-5...r/48464594 |
