![]() | Home > Puma (Tdci) > Instrument cluster |
That's a low range indicator but I'm pretty sure that it isn't actually used. Darren
andycam82 Member Since: 01 Feb 2020 Location: Bangor Posts: 25 ![]() ![]() ![]() |
Thanks Darren
Went out and put the car in low range to test but doesn’t light up. Interesting they never used it! Will continue to look into fitting the Ultragauge! |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543 ![]() ![]() ![]() |
Low range indicator light was used on Discovery 3 but not on Defender Puma Defender 90XS SW
Not talking about the PCB but does that mean the enclosure is the same? If I were to pick one up then I could modify the spare and then transfer across?
mmddbb Member Since: 15 Sep 2021 Location: UK Posts: 18 ![]() ![]() |
Hi, I am thinking of doing something similar. Because I didn't want to doing anything irreversible on my cluster I bought a scrap RR Sport/Discovery 3 cluster from eBay and stripped it down, in the hope that this would make life a bit easier.
While the PCB is different, the light guides all seem to be in the same place. The instrument backing plate also has a large aperture where the RR Sport LCD goes. The space is too big for the Ultragauge (see pic attached) so it is probably going to be a matter of gluing some additional material in there in order to make it the right size for the Ultragauge. Or investing in a 3D printer! While I've got the cluster out I intend to swap the dial colour and fit a Checktemp III - the latter will require a new cut out, but again I'd rather be cutting a spare than the one from my car, at least in the first instance! What I will say is that three of the needles on the gauges on the scrap panel were extremely tight - they wouldn't rotate against the needle stop and only came out along with their spindles, which I suspect has damaged the stepper motor behind them and means that they won't stop in the same place. Hopefully the ones one my car aren't as tight, otherwise I probably wouldn't proceed! |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Was probably mine that you saw. That light isn’t used on the defender. Plenty of space for the DPF lights in there.
I desoldered the LEDs and attached them to some copper track board. Then soldered cables to the right place and onto the instrument cluster. Nice and simple if you have the confidence. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
That’s great to know. I saw a freelander 2 cluster up for sale which I’ll give a go on. I’ll let you know how it works out ![]() |
Thanks Roy - it was your write up and install I’d seen. Not my area of expertise but will give it a go!
Also saw the rest of your dash mods, did you also change the back lights for the switches from green to blue? |
