![]() | Home > Maintenance & Modifications > D44 SPECTRE BUMPER & GENUINE A BAR |
| Trendkill110 Member Since: 04 Sep 2021 Location: Yorkshire Posts: 73
Hello.
My D44 Spectre bumper has just arrived and I've collected a Genuine Defender Soft A bar this afternoon. Does anyone know if I'm supposed to be cutting the part that's not letting it sit back and flush to the bumper? See photo. TIA 👍🏻 Click image to enlarge |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
I had to trip the inside edges of my A bar when I fitted it to a spectre bumper.
If you look at the back of the A bar, mine had “mould” marks where the cuts needed to be. Almost pre-formed areas that needed to be removed. If you look from the from currently it may look splayed out at the bottom? 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2541
I think the A-bar you have is for a std straight bumper - VPLPP0060, you need a different one for a winch or d44 spectre bumper - VPLPP0061 https://www.devon4x4.com/vplpp0061-protection-bar-408014.html
| mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947
If its a genuine A bar you will see the tooling marks to cut to for a winch bumper as Roy pointed out Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Pretty sure it's genuine 👍🏻
Click image to enlarge Click image to enlarge Click image to enlarge |
This line here. Trim this bit out abs it should fit flush 🤙
Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
