![]() | Home > Maintenance & Modifications > Topping up the power steering fluid |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1777 ![]() ![]() ![]() |
I thought it was just ATF for the Power steering box, pretty certain that's all I've used
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4271 ![]() ![]() ![]() |
I think when I looked into this I ended up using Central Hydraulic Fluid, not ATF. I asked Opie Oils, but it was a while ago and I can’t find the email now. 2007 110 TDCi Station Wagon XS
Spiritbeth Member Since: 24 Mar 2017 Location: Hampshire Posts: 15 ![]() ![]() ![]() |
I had mine topped up last week by my local Landrover independent as I had a graunching noise. He told me that it should be 'the red stuff' that is auto transmission fluid. When filling he said the level should be between the 2 marks when the cap is fully screwed on (not just dipped in). By the way, topping it up has cured the graunching noise. Hope this helps.
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Should be just normal red ATF, top up to level with the engine running. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 460 ![]() ![]() |
Thanks all, so is the abover Motul as suggested on the Opie site not correct? If not, any siggestions on the preferred ATF, again there are loads to choose from ?
Thank you. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
I use this, only issue is you have to buy 5litres:
https://www.smithandallan.com/products/tra...over-ace-/ Steve 02' 110 TD5 Double Cab Rebuild Thread |
Excellent, thank you. I guess it will come in useful!
Thanks again ![]() |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2338 ![]() ![]() ![]() |
Or just buy a 500ml or a litre bottle of ATF from Halfords or your local motor factors like everyone else does 😉
I’d agree totally with Mo above
![]() Unless you need something more extreme for your artic adventure… ![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Great, thank you all
![]() Just one last question, do I need fully synthetic? |
Only if you are adding to fully synthetic fluid already in your system and you don’t want to mix it. Ride like you stole it!!
OK, thank you. Sometimes I wish I had never checked anything! I dont know what is already in there so I guess I am safer just to change the whole lot, its only 1.6lt I think. What a flaming faff!
Thanks for the help chaps, much appreciated. |
westie_ Member Since: 06 Apr 2021 Location: Warwickshire Posts: 18 ![]() ![]() |
I always put ATF or red power steering fluid in it.
They should all do pretty much the same thing at the end of the day 110 Td5 Van |
I think the reality is that pretty much any oil that says it can be used in hydraulic power steering is probably fine. 2007 110 TDCi Station Wagon XS
