Home > Maintenance & Modifications > NAS rear step td5 - tow bar & electrics query
roche1800
Just fitted a NAS step and need sone ideas on tow bar and where to mount the electrics.
Adjustable height OR fixed…
The second and last pic show a bracket, there is one on each side.
Any info or pics would be useful, here are some pics as is …
Post #936865 8th Jan 2022 8:23pm
90 Dreamer
On mine I used a small adaptor bracket to mount the 13pin socket, some people have mounted them in the rear x-member
Because of the tow height I use a slider to drop the ball slightly in compariso the the fixed NAS settings
Post #936867 8th Jan 2022 8:30pm
The brackets with the cable ties through are intended for flat plates that are shaped and drilled to mount the towing sockets on. A far better location though, particularly if you're going the 12 pin socket route, is within the hole in the rear crossmember. It's a bit more of a faff to do as you need to drill holes for the socket and install rivnuts, but it's a much more protected location.
There's some details of how I did mine here:
https://www.defender2.net/forum/post879215.html#879215
As for the tow bar, that depends, to an extent, on what you plan to tow? Darren
Post #936870 8th Jan 2022 8:40pm
roche1800
Thanks for the replies, a flat plate will be perfect for me. Where do I get one from please
Post #936873 8th Jan 2022 8:58pm
DAZ110
You need something like this I think:
https://rimmerbros.com/Item--i-NRC8048--Se...tIEALw_wcB
Post #936891 8th Jan 2022 10:26pm
roche1800
Thank you for your replies.
For the sake of ease I will opt for the Rimmer Bros solution as it’s easy (and it’s on a nearly 20 year old landy!)
Post #936893 8th Jan 2022 10:45pm
Oldowner
NRC8048 needs the centre hole drilling out larger with a step drill otherwise the wires from the socket can chafe through, especially if using the genuine Land Rover socket.
You will also have to dismantle the multi plug and feed the wires through the hole, then reassemble the multi plug.
It is however a neat solution and how I have always fitted a 7 pin socket to a NAS step.
Post #936902 9th Jan 2022 7:15am
