![]() | Home > Puma (Tdci) > Egr connector how to disconnect |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 839 ![]() ![]() ![]() |
![]() Click image to enlarge So trying to change my vcv, looks like it’s not an original and whoever changed it before had the strength of 1000 men to do it up. So intake manifold is being removed, only issue is I can not get this connector off Any ideas? Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
When you say lift, towards the bonnet. Asking as I could not see any way that it moved I tried sticking the screw driver in most locations prying etc, don’t want to break the connector Searching for my first Defender...and started just as Covid hit, so talk about timing.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3586 ![]() ![]() ![]() |
That connector is exactly same as what VW use..
Watch this video.. Unsure if he mentioned it, but usually I need to push the connector in a little bit to remove pressure from the locking mechanism, and then pull it off as he describes in the tube. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks, this is the connector.
The issue I have is I can not see where to press, have seen a other video where they use a pic to push it up but don’t think that should be needed https://www.ebay.com/itm/262880271794?_ul=AR I’ll have another go tomorrow Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
There is no pressing to be done. It is a pulling action. The locking mechanism is kind of an L shape with a pivot ( imagine the L is inverted, up side down). When you pull on the short side of the L, it lever the ‘barb’ of the tip of the long side of the L which release the lock.
Remember that most times you need to push connector in a bit against its seal to remove the pressure from the locking barb. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Ok think I get it, thanks for all the pointers, tempted to go out now and try it, but I would prob not live to see tomorrow 😂😂 Searching for my first Defender...and started just as Covid hit, so talk about timing.
So still could not work out how to get to the clip, to perform the push down pull up motion , then I remember seeing mechanics standing on the bumpers.
Standing on the bumper gives perfect angle to reach in and get that pesky clip off. Thanks for your help and knowledge guys, now manifold off and let’s see if inc a get the vcv bolts out without snapping them. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 672 ![]() ![]() ![]() |
Try to clean the connector firs - with compressed air. If there is some trapped dirt, is is not possible to lift the locking tab enough to disconnect the connector. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Thanks MadTom it was not that dirty it’s off now, have not done the vcv though as the house build took priority today so was with my plumber hat on, tomorrow evening I’ll get back on to the mechanic jobs Searching for my first Defender...and started just as Covid hit, so talk about timing.
