![]() | Home > Maintenance & Modifications > UPPER TO LOWER BODY JOINT |
| 8619simon Member Since: 04 Nov 2016 Location: North Wales Posts: 265
Hi.... That looks to be a lot of foam in the gap.... What's the gap like on the outside?
It could be you have too much foam so it is not clamping down enough to seal. I only have a single rubber seal in that position and it seals fine. |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3653
Unsure if this is a HT (Hard Top) or a SW (Station Wagon), as the pictures show the rear sliding windows...
All SW that I know have an extra bit of foam due to the bulkhead delete, item 4 in this link: https://www.lrworkshop.com/diagrams/land-r...er_44867#4 My SW also have the additional foam on the inside of the standard sealing foam. I believe that is an attempt to make it a bit quitter inside, and is not meant to keep the water out. The outer seal, not visible in any of the pics attached should keep the water out. Ensure that all side panels to tub fixing nuts are tight, top and bottom. I had one nut come loose from the underside of the tub cappings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Looks like the wrong seal in there and also looks like it has a joint in it where the water is coming in.
| YANKEE MIKE Member Since: 09 Feb 2020 Location: Voorkempen Posts: 2
Thanks for the replies.
I'll check the outside gap one of these days and keep you posted. |
| All times are GMT |
