![]() | Home > Maintenance & Modifications > Anybody done rear door strut mod? |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3747
I did the mod for the same reason and it works. However, it makes it difficult to close the door from the inside. If you’ve got plenty of more senior gents in your shoot like we do, you find yourself having to shut them in, which is a bit of a chew but provides plenty of comedy! I ended up taking mine off again because it’s was more of an inconvenience.
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674
No photos but I have the version 2, it works well and stops the door closing on you all the time, however it opens quite enthusiastically so you need to learn to hold it as it opens.
I wont be removing it as I like it but its not perfect and a latched open system would probably be a better solution than the ram DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597
I had made my own contraption on my 90, very similar to what is discussed in this thread:
https://www.defender2.net/forum/topic6886.html What I had done differently is that I fabricated a bracket that bolts on the original 2 holes on the tub that extend forward for the forward mounting point of the gas strut. Then another bracket that bolts on the lower hinge bolts. This way, the door can open a bit further out.. just enough that a 7.50R16 tyre I was running at that time would not hit the tub when fully open. Probably I know where the parts are laying at the moment, as the 90 is still not together again.. if I find them I will post a couple of pics. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Bought mine from Paddocks, rubbish! So beware. Peter
| Rich h Member Since: 25 Jul 2021 Location: Leicestershire Posts: 31
I’ve just done mine last week got the kit from flee bay for £40 it works well and very easy to fit
