![]() | Home > Puma (Tdci) > Need help with hill starts with anti-stalls |
deep down Member Since: 02 May 2012 Location: France Posts: 204 ![]() ![]() ![]() |
It sounds like you might need to get your handbrake adjusted.
https://www.defender2.net/forum/post134568.html Once adjusted start practicing your hill starts, as it's a transmission brake it takes some getting used to taking up the backlash before releasing the handbrake. As for switching between Hi and Lo follow the method and again practice on flat ground. I double clutch at neutral point, I find it makes for a smoother change. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3631 ![]() ![]() ![]() |
Never change transfer box ratio at speed. There should be a decal in the dash and Landrover suggest to only change transfer box ratio between 0 and 5mph. I think 5mph is too fast. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3780 ![]() ![]() ![]() |
I don’t use the handbrake on any gradient of hill, I use the technique you describe. You might just need more practice, and I’d suggest start on flat ground to get your confidence up.
Agree with Dinnu re the transfer box change. Do it stationary. |
lakelander Member Since: 07 Jan 2017 Location: Cumbria Posts: 100 ![]() ![]() ![]() |
Does the anti stall only work in low range?
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378 ![]() ![]() ![]() |
No, anti-stall works in high range too.
I'm currently living on a farm and the speed that the anti-stall gives in 2nd (high ratio), is about perfect for chugging about. |
No, it works in high range too but it's not infallible and shouldn't really be used as a substitute for proper clutch control.
Firstly, as already noted above, get your handbrake adjusted if it won't hold the vehicle on a hill. Whilst the mechanism is different to ordinary cars, acting on the transmission rather than the back wheels, it's not 'a Defender thing' for it not to work in the circumstances you describe. To be honest, it just sounds like you need more practice doing hill starts. Your technique up to no.4 sounds fine but at that point you need to progressively balance letting the clutch out with applying the accelerator. It's not different from any other car but the clutch pedal may be heavier than you're used to. It's easy to write this, of course, but there's really no substitute for trying it out until you've got a better feel for it. Whilst using low range to start on a steep hill is a legitimate technique, it should really only be necessary on tarmac if very heavily loaded or towing a large trailer, for instance. The subsequent technique of changing from low to high on the move is not for the feint hearted and is much more tricky to get right than a practiced hill start. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 289 ![]() ![]() ![]() |
In my opinion anti-stall on tdci is excellent and more than capable of making hill starts in high 1st. except on the very steepest hills.
Whilst holding the vehicle with the footbrake select first gear, bring the clutch up to the biting point and then slowly release the brake pedal, simultaneously letting the the clutch all the way up. The anti-stall will do exactly what it says on the tin and fuel the engine to move away at idle r.p.m. Once moving feed in the throttle. Worth bearing in mind that as soon as there is throttle input anti stall is overridden 2011 130 Utility Body 2005 110 Van |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6016 ![]() ![]() |
As some above I don’t use the “hand brake” for hill starts, it’s not for that in my opinion it’s a park brake, especially on a Defender where it’s a transmission brake. You just need to practice the art of hill starts from what I understand from your post. Either gentle release of clutch using the anti stall, or using power but not too much. I’m thinking perhaps you just gave it too much power so were spinning the wheels. Another point I would add, is that you need to use your high/low and diff lock on/off so these things don’t seize and cause issues for you later.
I’d advise finding a big, but quiet hill and getting some practice done. The better you get the longer your clutch will last. So stay away from loads of revs. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4334 ![]() ![]() ![]() |
As above I use the anti-stall to pull away on gradients I usually get rolling with no throttle pedal at all, just bring the clutch up, release the brakeand then accelerate away once off the clutch. 2007 110 TDCi Station Wagon XS
fatduckling Member Since: 31 Dec 2021 Location: Sydney Posts: 8 ![]() ![]() |
Thanks everyone for your responses!
I think it boils down to two things: 1. I need more practice with hill starts so I'll work on this 2. Get my handbrake adjusted so it can hold itself on a hill. Also, how does the anti-stall work? I have the transfer gear in high range and main gear in 1st, and if I remove my foot off the clutch, it still stalls. I have a 2011 Defender 110, so do I need to set the transfer gear in low range for the anti-stall to work? |
It’s a gradual thing. As you slowly release the clutch and give some load to the engine the ECU increases the “throttle” automatically to prevent a stall. Of course you can still stall it if there’s too much load (maybe a big trailer on a steep hill) or just sidestep off the clutch, but the TDCi has a lot of torque at idle so it’s shouldn’t stall easily at all. 2007 110 TDCi Station Wagon XS
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 100 ![]() ![]() |
I well be told I do it wrong but: my puma is used with a demountable camper. When fully loaded it is 3500kg. We frequently go into mountains. When I have to start on a steep hill I stop the engine, engage low range (if it’s really steep). Put it into gear. Hold it on the foot brake, start the engine and let go of the brake. I do not touch the clutch. The truck just drives up the hill. Change gear as normal once underway
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 345 ![]() ![]() ![]() |
I love hill starts since getting my puma. Hill starts are quite possibly my favourite thing. I never use the hand brake when driving, its just a parking brake. Technique: Hold the vehicle on the foot brake, bring up the clutch gently, only release the foot brake gently when you feel the engine pushing against the brakes. Take your time moving your foot to the accelerator, the anti-stall is amazing so there's no rush. Anti-stall is a thing of beauty & creates the calmest of hill start experiences, however laden the vehicle. My tip would be to relax into it, almost to the point of sleeping, & experience the full joy of a calm slow-motion hill start. The defender will take care of itself. Forget what you've learned to do in lesser vehicles.
I won't say you are wrong, but I do wonder at the additional stress on the starter motor. You can move the vehicle with the starter motor but I've only used that on the flat and in an emergency. Also if the vehicle is in gear before you start the engine, I would have thought that made use of the footbrake redundant? |
